I'm finishing up the last details on a Turbo S bug revival and have lost the wiring for the auxiliary water pump.
Where should it be coming from? Does it come over from the passenger side or drivers? Which part of the harness or which other connectors are on the same circuit?
It was there when I started, the only things I have left to do is re-install the front body and lights.
Thanks.
Discussion Starter · #2 ·
Nevermind. I found it stuffed under the drivers side connector. Was just the correct length to look like it belonged.
