OK, people here is low down
hnoes: on the current cost of this project...
opcorn:
APH 2000 1.8T Cylinder Head Rework Real World Cost
Description....................................Price..........Each..........Amount
Clean and Inspect..............................60.00........................60.00
Align Bore Camshaft Journals...................(no charge)..................0.00
0.2 Install and Size Valve Guides.............................40.00.........200.00
Reface Valves..................................20.00........................20.00
3-Face Valve Seat Cut..........................90.00........................90.00
Lap Valves to Seats............................50.00........................50.00
Install Viton Valve Guide Seals #027 109 675...40.00........................40.00
Reface Valve Stems for Clearance...............40.00........................40.00
Re-Face Head Gasket Surface....................40.00........................40.00
Cam Chain 058 109 229B.........................61.80........................61.80
Camshaft 058 109 021B.........................260.00........................260.00
Chain Adjustor 058 109 217B...................159.80........................159.80
12 Intake Valve 058 109 601CIT................................19.50.........234.00
8 Exhaust Valve 058 109 611EIT................................27.60.........220.80
4 Intake Cam Follower 058 109 309F............................26.00.........104.00
8 Exhaust Cam Follower 058 109 309E...........................26.00.........208.00
Valve Cover Set 058 198 012 (Includes).......................160.00.........160.00
Valve Cover 058 198 025A
Valve Stem Seals 036 109 675A
Camshaft Seal 038 103 085 C
Tensioner Gasket 058 198 217
Cyl. Head Cover Gasket 058 198 025AS
Exhaust Manifold Gasket 058 253 039G
Head Gasket 058 103 383K
Serpentine Belt 06A 260 849C..................................38.00..........38.00
Water Pump 06A 121 011 LIT 60.00 60.00
Timing Belt Kit 06B 198 119 ( Includes)......................168.50.........168.50
Timing Belt Tensioner 06B 109 477
Timing Belt 06B 109 119A
Tensioner Roller 06B 109 243
Idler Roller 06B 109 244
10 Head Bolts 058 103 385B.....................................3.80..........38.00
Shipping Sent UPS on 5-12-11...................42.68.........................42.68
Total $2,135.58 (Yep!
This should be a reminder to always stay on top of your TB Maintenance)
Oil Funnel +Tax $ 12.39
Additional Tools
Hex Ball End Allen Wrench Set +Tax $20.84
*Estimated Total To Date: $2,366.96 :crying:
Only $487.68 more expensive from my
2.0L blown head gasket - Project Grand Total: $1,879.28
I did not add any taxes (unless noted) or consumables, like the permatex for the oil pan, CRC manifold/electric contact spray cleaners, the basting pans that I used when cleaning the parts, cleaning supplies, etc...
