101 - 120 of 140 Posts
No NB Yellow Trifecta :(
Discussion Starter #102
Unfortunately no progress to speak of ... :(
... the upstairs shower manifold started leaking and the plumber that put it in originally, soldered it in, :banghead: so I had to cut the fiberglass insert (all in one tub/shower unit) out to repair it. Which meant a bathroom remodel; so that is where I have been putting my repairs skills to use.
I am almost finished, just have to buy a hole saw kit to put a hole in the wall for the new manifold lever and then all I have to do is finish the drywall and paint.
Discussion Starter #104
Well, on one hand it is nice to have "free" car parts at your disposal when your spouses car needs one or two; however on the other hand it makes your project car budget seem to spiral out of control, not to mention make more work for yourself :banghead: ...
I have an old Fram Filter commercial stuck in my head ... "You can pay me now or pay me later."
Discussion Starter #106 (Edited)
No real progress, :( I have re-cleaned mounting surfaces and wire harness connections. Also I am waiting for a vacuum tube, secondary water pump and connecting hoses to come in. I also decided to replace all of the rubber hoses. Waiting on quote from German Auto Parts; I send them pictures with arrows pointing at the parts I need.
Aside from household projects, most of my time has been spent trying to find out why my '98 has been losing oil and coolant slowly. No ground spots, so it is draining and/or burning off when I drive; this morning I could smell it; subtle but it was there. Seeing how the '98 is my daily drive, I am going to risk driving it while I put my focus into the '00. The wife and I will be having a conversation that all other projects are on hold, including the household ones; which have been the bane :banghead: of my auto repair existence, so I can finish this project.
Discussion Starter #108 (Edited)
OK, well I have been busy; reorganized the garage to gather all of the parts that I still have, that get put back on and here is my tentative parts list of what I need to order ...
01) $ 12.10 - Cylinder Head Flange - 06A 121 132 AQ / 06A 121 132 H / 06A 121 133 Q
02) $ .85 - Cylinder Head Flange Sensor O-Ring - N 903 168 02
03) $ .49 - Cylinder Head Flange sensor Clip - 025 121 042 / 025 121 142 / 032 121 142
04) $ 14.92 - Oil Cooler Hose (Paired Hoses) - 1C0 086 N
05) $ 90.00 - Secondary Water Pump (SWP) - 039 202 002 4
06) $ 11.55 - SWP Auxillary Hose - 1C0 121 088 A ... from flange on upper radiator hose to SWP
07) $ 5.60 - SWP Auxillary Hose - 1C0 121 449 ... from SWP to frame tube
08) $ 4.05 - Coolant Hose - 1C0 121 096 N ... from cylinder head flange to frame tube
09) $ 12.45 - Coolant Hose - 1C0 121 447 K ... from upper radiator hose flange to expansion tank coolant tube
10) $ 6.90 - Coolant Hose - 1C0 121 449A ... from frame coolant tube to turbo coolant tube
11) $ 16.20 - Breather Hose - 06A 103 493 / 06a 103 493 BD
12) $ 28.40 - Breather Hose - 06A 103 221 BR / 06A 103 221 E
13) $ 21.50 - Breather Hose - 06A 103 221 BQ
14) $ 34.20 - Breather Hose - 06A 103 213 F
15) $ 7.50 - Breather Hose Clamps (x5 * $1.50) - 30032 / 943474 / HC 2232
16) $ 3.00 - Breather Hose Clamps (x2 * $1.50) - 30024 / HC 1524
17) $ 3.75 - Breather Hose O-Ring - N 904 673 01
18) $ 2.28 - Breather Hose Clip Spring - 037 121 142 A / 06B 121 142 A
19) $ 38.45 - Pressure Regulating Valve - 034 129 101 A / 034 129 101 B
20) $ 136.88 - Turbo Charger Bypass Valve - 034 145 710 A / 034 145 710 B / 034 145 710 / 078 145 710 / 028 014 210 8 / 302 333 2
21) $ 18.75 - PCV Bleeder Valve - 035 103 245 A
22) $ 80.75 - Vacuum Solenoid Valve - 1J0 906 283 B / 1K0 906 283
23) $ 321.40 - Secondary Air Pump (SAP) "D" Connector - 06A 959 253 / 078 906 601 D / 078 906 601 M / 721 851 310 / H 720 307 11
24) $ 51.99 - SAP Rubber Mounts (x3 * $17.33)
25) $ 256.20 - EGR Valve (aka Kombi Valve) - 022 131 101 F / 06A 131 229 / 06A 131 229 C
26) $ 2.96 - EGR Valve Gasket - 021 131 120 / 06A 131 120 A
27) $ 2.66 - EGR Valve Gasket - 078 131 120 M
28) $ 69.49 - SAP Upper Tube - 1C0 131 126 ... connects SAP to Air Box
29) $ 64.81 - SAP Lower Tube - 06A 131 372 ... connects SAP to EGR Valve
30) $ 73.33 - Boost Pressure Valve (aka N75) - 058 906 283 C / 058 906 283 F / 06A 906 283 E
31) $ 49.80 - Spark Plug (x4 * $12.45) NGK PFR6Q
32) $ 1.90 - Oil Cooler O-Ring - 038 117 070 A / 038 117 070 B / N 901 814 02
33) $ 8.30 - Oil Dip Stick - 06A 115 611 B / 06A 115 611 Q
34) $ 4.80 - Oil Dip Stick Funnel - 06A 103 663 B
35) $ 109.56 - Turbo Air Intake Hose - 1C0 133 354
36) $ 249.00 - Timing Belt Deluxe Kit (Includes - Timing Belt, Serpentine Belt, Tensioner Roller, Damper Idler Roller, Metal Impeller Water Pump and Thermostat)
37) $ 6.39 - Water Pump Bolts (x3 * $2.13) - N 909 450 01 / N 909 450 02
38) $ 6.95 - Special Tool T10092
39) $ 14.20 - G13 Concentrate 1.5L Bottle
40) $ 5.22 - Upper Motor Mount Bolt (x2 * $2.66) - N 105 167 01 / N 105 167 02 / N 905 167 02 / N 905 969 02 ... mounts to frame
41) $ 7.80 - Upper Motor Mount Bolt (x2 * $3.90) - N 102 096 03 / N 102 096 05 ... bolts upper motor mount to lower motor mount
42) $ 7.00 - Short Lower Motor Mount Bolt (x2 * $3.50) - N 907 124 03 ... DEALER ONLY PART ... mounts to engine block
43) $ 6.53 - Long Lower Motor Mount Bolt - N 103 280 02 ... DEALER ONLY PART
44) $ 8.00 - Crank Pulley Bolts (x4 * $2.00) - N 103 036 07 ... DEALER ONLY PART
45) $ 21.50 - Cylinder Head Bolts (x10 * 2.15) - 06A 103 385 A
46) $ 18.00 - 6 Point Poly Drive Tool ... for cylinder head bolts
47) $ 122.11 - Fan Control Module - 1J0 919 506 K / 1J0 919 506 Q
48) $ .00 - Control Relay ... AL borrowed it for testing Cup
49) $ 19.35 - 3 Meters of 3.5mm Cloth Braided Vacuum Hose
Total Cost $2,059.82
Keep in mind that some of these parts were cannibalized and used on the wife's NB and others I cannot find.
Ugh! Stealing from Pete to give to Paul; it must be frustrating, in the long run! Then, you have to replace, purchase everything after you cannibalize your project car! Where did all the parts go? Who stole them? Stop Thief! :stickpok: :rant2:
Discussion Starter #110
Yep, I did and now I reep the rewards! :banghead:
Finally! :eek: Lets get this thing fixed and back on the road! :goodjob:
We are all rooting for ya; the last of your New Beetles and with a 1.8T, the most fun to drive!
:thewave:
Has this project; really been on the back burner since 2009? Whoa!
Discussion Starter #113
:thewave:
Yes, this project has taken a back seat to everything else! And that has now changed! :)
In Frank's defense he was keeping 3 other beetles on the road in addition to trying to work on this one.
Waiting on the big reveal.:D
Hello D2beetle,first let me say this is a great thread very informative,with great pics! I recently blew my belt or tensioner on my 2000 1.8 beetle,im in the middle of taking the head off to check for damage,i have been following your steps which are great,im just about ready to remove the head,as I got everything disconnected except the belt,which I'm starting on tomorrow.The belt is still snug,does not look broke,wont know till I remove the mounts and lower cover,but the cam jumped to about the 3 oclock position.I have a question for you,can I remove the head without setting to TDC and then remove the belt? Then turn the crank to TDC and replace the head and belt.Any help would be appreciated.
Discussion Starter #116
Since you are removing the cylinder head, there is no need to set TDC, as you can do that before you put the rebuilt head back on. Be sure the machine shop that you take it to, sets the cams to TDC on the cylinder head. That way all you have to do is bolt it on. But, be sure and double check their work anyway.
Discussion Starter #117 (Edited)
Update ...
Now that I am down to one Beetle, I am making headway. All of the 2.0L spare parts are gone and I have been going through what parts I have that can be put back on and I checked those against the ones on order; I am still missing a couple of hoses and a temp sensor.
So part clean up has begun ...
Thank you!
Discussion Starter #119
Thank you!
Anytime! :D
The cylinder head on my 2000 beetle 1.8,after blowing timing belt.You can see the valve strikes on the pistons,and the bent valves.I would like to thank d2beetle for the great step by step thread that helped me get the head off.I just got the head back from the machine shop who did a complete valve job,and I installed it back in today.I replaced the timing belt,water pump,tensioner,thermostat,coolant pipe,alternator tensioner.Im in the process of putting the alternator back in,as I moved it down to replace the thermostat,once that's done I will be firing her up.A quick note for anybody else doing this,i unbolted the intake and just pushed it back a little to get head off,also left the turbo intake tube connected,no need to remove and also left the air pump in place,did not remove.
