I have completed a "search" of the forum threads, to assist me in determining why the new battery in my 1999 2.0 NB will drain to the point I have to jump start it or put a charger on the battery after about two days of setting idle. After reading the threads, I see that the radio could be the culprit. So I had a friend of mine, who is a mechanic, conduct a search for battery drain in the NB. Sure enough, he learned that the radio, even though it is off, will drain the battery to a point that after two days, I will need to recharge it.
From the forum, I see someone suggested locking the doors at night, as this should put the system in a sleep mode. So I had the mechanic check this out. Though locking the doors does reduce the amount of drain, it would still drain the battery after about three days.
So my question - why do the VW factory radios drain the battery, even when they are off?
What have others done to remedy the problem? Short of installing a simple shut off switch in line with the radio fuse, so as to "kill" the drain, what other options are available? I know I could remove the fuse, but then when I want the radio on, I would have to put the fuse back in. Thus my reason for suggesting some type of shut off switch?
Frustrating!
Frustrating!
