Troubleshooting
BATTERY DISCHARGE
The normal parasitic drain on the battery of a Beetle or Jetta is 0.05 to 0.06 amps. This drain occurs when any door is closed after the rear hatch. For some reason, the battery drain is as much as 0.075 amps if the last "door" closed is the hatch and not a passenger or driver door.
Anyway, any drain of 0.18 amps is not normal and it will eventually lead to a low battery state of charge which means the failure to crank and start the engine. The original amp-hour rating of your battery is around 72 AH for a TDI battery. Overnight, a 0.18 amp discharge will net you a 2.2 AH loss (amps times hours). In one whole day it amounts to 4.4 AH or 6% of your battery's capacity. Since your battery certainly won't start your car below 60% of its total capacity (43 AH), its important to find the source of the battery drain.
I strongly suggest that you keep a charger on your battery while it's parked overnight until you find the source of the battery drain. Even a trickle charger will completely counter act the battery drain until it's located and fixed. It will also prevent permanent damage to the battery which will occur if it is continually left in a partially discharged state.
A drain of 0.18 amps is typical of a single 12 volt relay that is continuously energized in the vehicle. I assume that you measured this battery drain by disconnecting the negative battery cable and inserting the DVM between the battery terminal and the cable when the meter is set to measure amps. If so, the reading should be reasonably accurate. Make sure that you confirm that this drain is constant thru at least 4 or 5 minutes after the meter is hooked up -- not just 30 seconds.
A lamp in the glove box or in the hatch area will draw more current (at least 0.3 amp) so that type of load cannot be the problem. You can attempt to isolate the offending electrical load by removing individual fuses in the in-dash fuse panel until the battery drain drops from 0.18 to a stable 0.06 or 0.05 amps. You can also begin by removing relay 109 (load reduction relay) under the dash in the thirteen fold relay panel. Note that any relay that is energized continuously will be warm to the touch. So just touching relays in the panel can tip you off that one of these is energized. In addition, there have been problems with the radio when the amp section of the monsoon radio does not completely shut-off causing battery drain. Pulling the radio fuse can isolate this problem.
It is possible that the parasitic current draw is from the alternator. If this were to occur, pulling fuses won't locate the problem. This is not the most likely source of the drain, and removing the large cable from the 6 mm stud on the back of the alternator can verify or eliminate it as a source of the problem (engine off and your ammeter connected).
Also, think of any modifications to the electrical wiring or the addition of a new accessory that may have been done to the vehicle in the last month or two. A new radio or fog lamps, etc. It's possible for a mod to create an unintended continuous battery drain.
