Guys were can i get a head for my car ? The mechanic says I need a new head for my engine . Are heads hard to find ? Do they sell refurbished heads for a 2009 model beetle ? is there a difference between stock heads and performance heads ? Just asking since i saw performance heads I would ask, rest of the car is stock so I guess the heads probably want do that much ? Hope is some one out there that can help .
Where are you located? You posted in the 2.0L section, but if you're in the states then you have a 2.5L.
SO I have my vin number can that help with getting right part?
vin# wvwzzz1yz8m420199
hope that helps . I need a heads asap pls help
Hey, seems to break down into:
New/used/rebuilt: new insanely high, used allot cheaper and rebuilt probably the middle price range.
Sources:
VW dealer:
VW Parts | Volkswagen Parts
new: $5700
rebuilt: $2500
Aftermarket shops:
eurospec.com specializes in VW engines/heads. They have a ebay store: list this head, you might call to confirm with your vin #:
$950
Cylinder Head Rebuilt 2005 2013 VW Golf Jetta 2 5L 5 Cyl Code Cbta Cbua | eBay
contact info: [email protected] or 01 408 848-4203
eBay: used $165 and up; used hard to know if it is in good shape or the correct one for your car; if you decide to go this route: I would take it to a rebuilder/machine shop, to confirm everything is ok, it may need to be rebuilt or have machine work done to it. At that point: costs: rebuilt read to go vs. local shop doing the work, becomes a issue.
volkswagen 2.5L cylinder head | eBay
Local junkyards; auto recyclers:
You might call around your area and see if they have a used head that would work.
Another place: Ram Cylinder heads in Missouri: $995
Volkswagen 2.5L 5cyl
All things being equal, prices being essentially the same: I would go with Eurospec, they are well known in the VW community.
Local repair:
Another option: work with what you have, is it repairable or damaged? It comes down to: price, how quick you need the part and if yours is rebuildable.
There are other places but these came up with a quick google search. Hope this helps: let us know, what route you want to go.
So what exactly is wrong with your head for him to tell you that you needed a new one??
