Hi,
I have a 2000 Beetle GLS that I bought recently. The other day , check engine light came on and gave me P0302 cyclinder 2 misfire and P0171 bank 1 system too lean. I resetted them and unsurprizingly they came back after about 120 miles.
I have been reading about the codes. So, P0171 may mean a lot of different things from MAF to vacuum lines. So do you guys think that P0302 is connected with the P071 code. By the way is P0302 an ignition coil problem or just the spark plug on cyclinder 2 needs a change?
Thank you in advance.
