The fans in my 1999 Beetle will not run. I have checked the fuse, it is good. I have tested the fans - by running a wire from the battery to the each fan. Each fan runs when I provide 12 volts. So I know they are good. All the hoses get hot when I run it. I also changed both temperature sensors out with new ones but the fans still won't come on when it gets hot. Why not, what have I missed? What is my next move?
fans
Most likely your fan control module or the fuse box on top of the battery box. Sometimes you have to wiggle those 30 AMP fuses because they lose connection inside the plastic box.
