1 - 10 of 10 Posts
I have a '99 Beetle 2.0. that continues to over heat despite all attempts to fix it. The original problem is that the water pump broke. I installed a new one this morning, and its still overheating. I have replaced the following:
Water pump
Thermostat
Cooling fan assembly (Low speed didn't work on the 12" fan)
Radiator fan switch
I can jumper the radiator fan switch, and make the fans run in low or high, but they won't run on their own. Also, the heater no longer blows hot air after refilling the system with coolant.
Help!
I have posted up the correct Bentley diagnostics for the cooling system in this thread.
http://newbeetle.org/forums/2-0-liter-gas/52013-overheating-problem.html
You need to review them, and verify what you have done is correct.
If you have correctly jumped over the thermal switch, and the fan runs, even though you have replaced it, it is bad. Again review the procedure for doing this in the Bentlet diagnostics. OR the sensor is not reading correctly, quite possibly by the flow of coolant not being right, as indicated by the second part of your post, having no hot air There is also a recent thread in this regard.. Their is air in the system that needs to be purged (burped) out. This is not the Bentley method, that is done by pressurizing the system with an external device, but many Orgers have posted up ways to do this. Quite possibly you did not get the system fully drained. You should measure what is going in to know that it is full, if the system was completely drained.
MORAV
Ok, heres where I'm at now. The car is still getting too hot, and the fans will not kick on when they should.
When I open the radiator drain, it will blow air for a couple of seconds, then hot water runs out and the fans will kick on and run for a bit. After closing the drain plug, refilling the reservoir (with the water I just drained), and letting it cool down for a bit, the process repeats itself.
The heater works now, seems it had air in it.
So apparently I was right about that being the cause of the thermo-switch not kicking the fans on or you having heat, but you probably still don't have all the air out of the system, hence the recurrence. Search around the threads until you find the DIY method being used by other Orgers to purge the system of air.
If I can find it, I'll post up the correct method as outlined in the Bentley.
M.
Coolant Drain & Fill Procedure per the Bnetley Repair Manual
You can find more information on the VAS 6096 Charging Unit here
http://www.audi-forums.com/b5-forum/55615-another-overheating-problem.html#post165098
and the unit, available from Snap-On here
http://vw.snapon.com/SpecialToolsDetail.aspx?itemid=120013
Pay particular attention to starting up the engine with the heat and a/c off. Notice the rpm to run it at and the duration, and then continue to let it idle until fans cut in. Check level and top as necessary. The way I'm reading this, this should be independent of using the VAS 6096 Charging Unit
Let us know how you fare.
MORAV
Ok, looks like I got it fixed. Just sitting at idle, the fans kick on and run at low speed for 10-15 secs, then cut off for around a minute. No overheat warnings, and the coolant seems stable with the expansion valve off the tank.
Took it out and drove it 12-15 miles in the Oklahoma sun this afternoon, ran fine on the highway at 70 mph. Had to have been air in the radiator that was trapped, preventing the fans from running.
Thanks all for the help.
Glad you got 'er up and running. Feel certain it was air in the system that has now worked it's way out. Did you have to top it off again, or have you checked it?
FYI Coolant cap. for 06 2.5 Beetle 9.5L/10qt
Just fyi. I could not find teh capacity in my OEM manual. Had to go to the mountain and ask the local VW dealer service dept. Ha he didn't know either. Their method is flush and fill with one gallon. Pushed it and he finally found it, 9.5L/10 qt. Which for my model makes a flush + 1 gallon 60/40. Manual says 50/50 or 60/40 coolant/H20.
Yep, when I did my flush and fill I had to run the car for 45 mins with the top of the reservoir off to allow all the bubbles to come to the top of the system. Occasionally I would squeeze on on the upper or lower hose to burp the system. Test drove and then topped it off.
1 - 10 of 10 Posts
