1 - 10 of 10 Posts
My 2015 beetle is Candy White. It's just a fleet edition. But she's coming around nice I think. First it was all factory. Then I played with the wheel color on the factory 16" rims. Went white with Plasti dip. Looked great for a month. Then went down from there. Peeled it off back to factory. So I then took the plunge and I painted them black. That was a job. She sat on jacks in the garage for a week. The rims had some nicks in them. Long story short. After much wet sanding with different grits and primer and more sanding. I now have black rims. Then I was in a painting mood and after looking at some pictures of nice Bug's. I added some touches of blue. Not sure if I should do the calipers or not. I'm just doing a small idea at a time. I don't want to over do it with the blue. I just don't want to be like every other white Bug. I also played with the rear tail light. I got some 35% window tint and just put a piece on it and sat it back on the car. I didn't like it. Just didn't do it for me. Looks good on other car's, but I just didn't like the look. Even though it was not dark. Just 35%. She's a slow work in progress.😉Hope you like it. Give me your input ☺ I'll post my stereo system in that topic section. I did the last two today.
Discussion Starter · #2 ·
I did this today. I had only done the splash pan right in front under the bumper. But I wanted to fix those scrap's from rubbing the corners on steep enter and exit driveways. So paint the whole front bumper and hope that they can match the new paint with the old. Or I can just save a ton of money and just do the bottom blue and put the splash pan back flat black. I did remove the splash pan before I painted. Thinking about the calipers next. Idk yet.
Interesting, it looks like your theme is beginning to take shape; you might take some photos of the body of you car. Then, do some color and design studies; you could use drawing programs or use traditional colored pens, pencils, etc. to explore, ideas and color schemes.
The Beetle was used in the GRC racing series and looks similar to the classic 911 Porsche body design. You might look at GRC and historical Porsche racing cars for inspiration.
Online, the German Sunshine Beetle show, the Sidney Industries show car and various facebook Beetle groups like those from Czech Republic, they have some really great looking 2012+ Beetle customized cars, on there.
I've found a couple white one's, but they have red accents similar. I didn't think about a pic and a program. 👌👍 Painting it is the easy part 🤣 all the darn taping and prep is a time killer. But you get what you put in.
Update.. did the calipers today.
A little darker blue, but I kinda like it.
So I took them off one at a time. I clamped the line right at the caliper, but I had a ' not thinking it through ' moment. I totally knew that I would lose the fluid out of the caliper and would still have to bleed the brakes. I was just thinking about the fluid coming out of the lines. 😕 I took them off because I'm anal and that's me. Most people just tape up and cover up stuff. But you can only get it so so clean and they paint over everything. I don't like that. Hope you like it. Used a t45 for the 2 caliper bolts and a 10mm for the line. 7/16 for the bleeder valve. Wire brush, drill with wire wheel, 320 w/d sandpaper, brake cleaner.. 1 can per caliper.. masking tape, and 2 cans of VHT caliper paint blue. 5 coats. 3 would be fine. Even with 5 coats I only used just a little bit more than a can for all. I just over kill. Razor blade. Pitcher of warm water to warm up the paint before use. 5 minutes soak is enough.
Discussion Starter · #7 ·
I got lazy. Or smarter 🤔 this is much faster and easier than taking it off. Plus I didn't have to bleed them. Still looks fine. If it was a show car, then I'd just powder coat them. Just make sure you tape anything that you don't want to paint 😉
Discussion Starter · #10 ·
Thanks. When I get around to it, I'm going to match the blue on the wheels so the other blue on the car matches that color. Not sure what I'm going to do with the caliber color. I was going to paint the part of the hub/rotor, I don't know what you would call that part that the wheel butts against when it's in the car. I don't know if I should go with like a satin black or do I match the wheel color. It's like a very deep black cherry color. When you look at them, they look black. When the sun hits it just right, you see the cherry tint. I also want to paint the dust shields for the brakes. That will be black. I just don't know yet what type of finish I want. Glossy, satin or flat. Pretty sure it's not going to be glossy. Not for a daily driver. I just want to clean it but behind the wheels. OCD. Lol the rusty looking part behind the rim. I know that I don't want to paint the front of it. And the brake shield. I might try to clean them up and see. Either way, I'll probably take it off if it's not a pain. Haven't looked yet because I'm been busy with the wife's truck. It needs some TLC in the inside. Good old Chevrolet plastic dash and the other high grade plastic they use is so thin that it just gets brittle and crack's or breaks. It is 12 year's old, but it doesn't look like it.
1 - 10 of 10 Posts
