So I have determined that the struts on my 2003 1.8t GLX Convertible with 82k miles on the odometer are in need of refresh. I had looked around and did not want to invest a bunch of cash and found that BlauParts had a very nice and complete strut kit for $280 shipped. Looked like a very complete kit and they claimed the strut/shock valving was tweaked fore the Beetle. Not so sure the valving was tweaked, maybe it was just a different application??
Anyway I ordered the kit, promptly received email confirmation that the order was accepted, within 3 hours I received a shipping confirmation that things were moving. 2 days via FedEx Ground from WI to VA.
Came home about 1 pm today and the package was on my doorstep less than 48 hours after placing the order!
Very complete kit, gas struts and shocks, rear upper shock mounts, front upper strut mounts, front strut bearings, compression bumpers, dust tubes, hardware and anti-seize compound, Loctite. Most parts are either OE or Mahle. Not sure who`s struts/shocks are used?
I have already swapped out the rear shocks, the only think I needed to reuse were the upper strut mount to body bolts and the upper strut mount half sphere dust cover.
Swapped out the rear shocks in about 1 hour taking my time, having to find my tools, ramps, jack stand and floor jack.
Everything that was needed was included, went together without issues and all I can say is the original rear shocks although they had not leaked were rather weak. They did not appear to have a strong amount of gas charge left in them and one seemed to have a bit of air it it when compressed. The new shocks were FAR superior in their dampening and return.
I took the car for a ride even though I had not swapped the front struts yet. I could tel am immediate difference just with the rear struts, nice improvement.
I am hopeful to swap the front struts in a little while today as the temps are finally starting to drop. I had 104F on the NB outside temp display earlier today!!
I believe at least one of the front struts has little to no gas charge left and I am excited to see how the car handles and behaves with all 4 struts/shocks refreshed.
Update - Finished installing both front struts. Both of the original struts had no gas pressure to return the piston. Not sure if they were originally gas pressurized, assume they were?? One challenge was getting the original struts out of the steering knuckle. I figured out how to make an $0.80 tool to keep the steering knuckle spread slightly so the old strut tube could be removed and the new strut tube installed. I used the end of a crow bar and a rubber mallet to wedge open the steering knuckle then I used my $0.80 wedge to keep the knuckle loose while the strut tubes were swapped.
I could not find any specific markings on the struts or shocks, they appear to be OEM supplied to BlauParts. Overall I see no quality concerns with any of the items I have purchased from BlauParts. My initial impression is all quality parts, very complete kit, very reasonable price and the end result of the ride quality and handling is a great improvement over original struts that were 10 years old and had 80k miles on them.
Again, this may be the most complete kit and likely the best price that I have found. It would be nice if they added a torque value sheet and a diagram for how the bump stops and bearings install, however, if you pay attention when you disassemble things it should not be an issue.
Pictures below.
Pictures below.
