I had a leaking heater core. Replaced it resently.Im not getting enough hot air. Heater core is hot, but the blend door is not closing enough. Can I block off outside air some how till I can tear it out again?
Did you repair the blend doors at the same time? If so, you probably have a cable out of adjustment. To answer your question, just press the recirculate button and you will close off the outside air.
