Do you mean; turn signal lights (how are they acting)? Hazard/turn signal switch do burnt out (in the dash below the radio); some have gotten them to work with contact cleaner (this case, turn signal blinked once and then stopped). If you have nothing; I would test the hazard turn signal switch in the dash and replace if bad. You might also check the turn signal assembly in the column; they have been know to ground out and stop working correctly or intermittently.
http://newbeetle.org/forums/questio...eetle/34416-turn-signal-failure-take-2-a.html
Welcome to the great and wonderful ORG! Many fantastic cars, people and answers lurk in this great land. If you haven't done so already, take time to fill in your profile and post a few photos so we can ORGle them!!
As other poster indicated there are several things to check - if it were a bulb at least one of the other bulbs should work. I'd check the flasher and then the assembly on the steering column.
