I've not seen this happen, but the MIL will be on and the engine will not run as good since the turbo impeller slows way down.if you put a bov on your stock beetle without doing a computer tune every time the bov realeases your car will die.
I know its been over a year you put this post but any pics?Indeed you will get that sound from a short ram. Plus a decent short ram is a lot less expensive than a blow off valve. I paid $25 for a Spectre cone filter and like $10 for the secondary air intake hose filter. I also removed the stock intake box and tubing leading up to it and installed a 3" diameter flexible hose with one end behind the grill and the other leading up next to the filter so its not only sucking in hot air.
Really hmmm? Ok well if you do find em that would be cool.I actually just took it off and put the stock air box back on. I don't think I have pictures. Let me dig a bit and I'll post them if I have them. I do miss the BOV sound though. But the stock air box breaths a lot better than a cone actually. I'm reading at least a couple more inches of vacuum on the stock air box than I ever got with my cone filter.
put a snake in your air box.How would i go about putting a blow off valve on the stock turbo on my beetle so that i can get that hiss sound? Does require any major modification? Thanks.
If you put a Blow Off Valve on a 1.8T... people will laugh at you.
What of putting a blow off valve on a 2.0LI've not seen this happen, but the MIL will be on and the engine will not run as good since the turbo impeller slows way down.
Putting a blow off valve on a 1.8T is a bad idea. PSSSSSSFRT doesn't make the car go faster, if anything, it will make it slower.
2 big reasons the engine has a Diverter Valve instead of a Blow Off Valve:
* Keeps turbo impeller spinning at a higher RPM as compared to a Blow Off Valve when the Throttle Body snaps shut.
* All metered air in accounted for, better efficiency.
If you put a Blow Off Valve on a 1.8T... people will laugh at you.![]()
My beetle is a 2.0l and I was thinking of putting a blow off valve,is it a good idea?What of putting a blow off valve on a 2.0L
Totally untrue if we are talking turbosif you put a bov on your stock beetle without doing a computer tune every time the bov realeases your car will die.
pointless a blow off valve blows off turbo pressure you don’t have a turbo!My beetle is a 2.0l and I was thinking of putting a blow off valve,is it a good idea?
