Different year models may have different fog lamp assemblies where the bulb access is different from mine, so I can only guess as to the simularity of yours to mine. Most fog lamps require you to disconnect the connector off the rear fog lamp cap.Turn the rear cap portion of the lamp counter-clockwise pulling down. Disconnect the unshielded ground wire for the bulb and sqweeze the top of bulb retaining clip and rotate downward to release from reflector housing. Install is just the reverse. Never ever touch the bulb with your bare hands, fingers, ect. Use a paper towell or suitable protective covering when installing bulb back into the reflective housing. As stated in other posts, the replacement bulb is just a normal H-1, 55 watt bulb available at most any and all auto parts shops. Good Luck, JK
