Just purchased a used 2013 Beetle and wanted to know how can I tell if it has bluetooth?
I went into the radio (RCD-310) and there was a selection in the setup for BT-Audio, I set it to ON. Now when I go back into the setup menu the BT-Audio selection is not there?
I can't get it to pair since I don't see the VW bluetooth in the list on my iPhone 5.
Help!
I believe bluetooth came standard on the '13 model? I could be mistaken. Maybe your phone's blue tooth is off? I sometimes forget to turn mine on, causing of course lack of connectivity.
If you saw the bt audio, you havd blue tooth. On my '13 it seems to have a delay on the blue tooth for audio. Try having your phone on the blue tooth menu then start the car, it should look for the phone on initial startup then you can pair it. The dealership paired mine so i dont remember the exact step.
