cooling problem
We were working on the NB all weekend to correct the no flow problem.
Testing thru the radiator with a garden hose, top hose filling and bottom hose removed from the bottom of the radiator. Water flowed fully with no backup.
The air filter was removed to gain access to the small hoses at the throttle body. Again the flow of water from the bottle hose thru the throttle body and out seemed to be non plugged and full flowing.
We replaced the plastic heart fitting and found the outlet to the transmission heat exchanger(think that is what it is) plugged. The entire inside of the assemble had scale build up.
Pictures of of this fitting.
The thermostat was removed and boiled, it opens. Not an easy task. I put a mirror in the opening and saw the nut and some blades of the water pump. Not a very good view. I could not reach the blades with my hand as others have done. The cnnection pipe for the hse here had some build up, more than what I would think reasonable.
Running the car, I observe: Hoses at the enging get hot near the engine only. At the radiator they are still cold. The bottom hose gets hot near the thermostat but not at the radiator bottom connection. Fans without a signal of heat still fail to run.
We are running with water only at this time.
The car ran hot with the red dash light flashing, still cold bottom hose at the radiator bottom.
The engine has a chirp............
I will get a VAG real time program, I have to have a connector as well.
The flow back to the fill container is weak, a small stream.
We do have cabin heat.
I am thinking too many things to make a judgement of the guilty part.
Thanks in advance......Mike03
Actually, I have to add, I am learning about the car.
The pic of the hose to the brake booster if clear would show a crack and potential problem. Looking for a miss, it might be here.
