Does any one know if the engine is tied up with the breaking system ? I already changed everything I could think of calipers booster master cylinder and it still looses pressure I've bleed all the lines and master cylinder like 100 times and still nothing the ONLY thing left I can think of is that the engine isn't running in tip top shape and when I press on the brakes I can feel like the engine kinda dies in a way ? Any ideas I really need help and I really don't wanna take it to a shop it's wayyy to expensive and money is short !
What engine. there is a vacuum line between the brake booster and the intake manifold, With a leak in it you would loose brake pressure and the extra air effects engine performance.Did you cahnge that line when you changed the booster and master cylinder?
