My Beetle has this weird braking problem. When I step on the brakes and goes almost to a stop, the ABS (I think) engages. It does that almost everytime I stop. Could it be the sensors? I tried cleaning it but did not help at all. Does anyone had this problem before? I have a 99 Beetle 2.0.:(
What makes you think it's the ABS kicking in?
Does it shudder? Does the brake pedal push back real hard? I don't think '99 2.0's had any kind of ASR/ESP do they?
Cleaning the sensors was a good idea. I would think any other problem w/the ABS would kick off some sort of brake light. (bad connection; invalid sensor readings)
Could it be warped rotors?
Yes, it shudder like typical ABS and you'll feel it kick-in at the pedal so I'm pretty sure it's not warped discs. I also think it does not have ASR/ESP. Would it be better to let the dealer diagnose the problem? I fear that they would charge alot for it.
a.k.a. porkchopzz4
But if it is a malfunction, that should illuminate the ABS light or the BRAKE light. I've got an occassional ABS light which is throwing a left wheel speed sensor code intermittantly.
Never felt the pedal kick back - except when I had warped front rotors, the pedal would pulsate. Replace rotors and the problem went away.
ABS Light
On Saturday, I had my ABS light come on after driving for a while. It came on the next time I turned on the ignition, stayed on for a couple short drive cycles, then went back off. So far, it's stayed off.
Now, I did replace my front brakes & rotors. I bought a couple of ECS Tuning's Slotted / Crossdrilled Brembo rotors, and I'm wondering if the either shavings from it, or the Mintex Red box Pads are messing with the ABS sensors. So, I'm guessing I had a temporary problem, and I hope it won't come back, or else I'm gonna need the stealership to VAG-Com my car to see what's up.
Anyone else have this particular problem?
Thanks!
I had a friend's ABS sensor plug get stretched so that it didn't stay tight. That was a cheap fix.
I've bypassed a brake pad sensor to have the wires get pulled out and throw a brake light.
If you just did your own brake Teddy, I'd check the connections. Maybe run a paper towel over the sensor rings. Shouldn't be all THAT messy. & from the brake pad thread; I'd suggest you sand your pads just in case they are glazing... can't hurt.
