1 - 16 of 16 Posts
Does anyone know what the part is I need to order to fix this? It's the hard plastic hose thing off the brake booster. It has a 2 inch crack in it and it separated completely while I was driving. I have a 2005 vw convertible bug automatic 2.0 engine.
:confused: I included a few pictures so you can see the cracked part. I put it back together with duct tape for now, but that's kind of scary. Hopefully I posted this in the right place, I'm new to these forums. I have to keep driving this till I can get it fixed, so I'm hoping I can get the part cheap online or something.
No NB Yellow Trifecta :(
If you want the original plastic tubing, you will have to get that at the dealer; however it can be replaced with a regular hose. Just make sure the hose is stiff enough not to collapse under vacuum.
Thank you, the hard plastic part has a two inch crack and it completely separated from the top part that gets inserted in to it.
hey
Hey if you want to save ya some money and it's worth a shot why not try JB Weld and patch that plastic thingy. Jb weld bonds really good and is not affected by heat, oil or gas. good stuff and it's only 3-4 bucks at walmart....just don't glue your fingers together. :p LOL
Discussion Starter · #7 ·
Thank you, I thought about jbwelding it .... I want to make sure it stays fixed, so I just went to the dealership and I have the part coming. Ever since it broke my check engine light came on. I went and got my oil changed and they said they don't think anything else could be causing the check engine light to come on that they saw. Could a brake booster hose make my check engine light come on?
Older but not Wiser
oh yea it will make your CEL come on... mine cracked right at the brake master cylinder. that lil doo-hickey was $120ish. not happy with oem part prices. im not used to paying full price!!!
-jd
Discussion Starter · #10 ·
Thank you, I appreciate all the help. I'm going to pick up the part now. :) I'll be glad to have everything back in working order.
JB Weld or any other glue product will not fix this problem; the plastic shrinks, becomes brittle and splits down the length of the tube.
I have the same exact problem - crack in the same hose (see pic). Does anyone have the OEM part number? The brake booster hoses I've seen online look a little different. I have the Bentley book and it's not much help. Also if anyone has replaced the lower section with a regular hose- any tips on what kind of hose and where to connect? Hard to see where it connects- I'm assuming a vacuum pump. Any help would be greatly appreciated!
Contact the parts dept of your local vw dealer with your vin #; some brake booster hoses are being reproduced by the aftermarket but some are available as genuine vw parts only.
Yup, I contacted the parts dept right after I posted, and just heard back. The OEM part number is 1J0-612-041-HE...and the dealer quoted me $106, plus tax. Wow. I asked if he knew where it connected to and he said that parts catalogue didn't say. I'm wondering if I can sleeve it rather than replace it. The hose that runs to the intake manifold has a sleeve where it connects to the tee.
I have used electrical tape with some short term temporary success. However the real fix is a new hose. Try metalmanparts.com, rockauto.com. fcpeuro.com. If you can't find it on their websites give metalman a call.
For anyone else
Thanks! I might try duct tape until I am able to replace the hose. For anyone else wondering I finally figured out where that lower hose connects to - its called the brake system vacuum pump (V192). The pump apparently is attached to the subframe near the drivers side wheel somewhere behind a control arm it looks like. If you have the Bently book its at 47-19. I won't be able to get the car up off the ground at least for the next 5 days or so, but it looks like it's going to be real fun to get to where the hose connects to the pump. Yeah, maybe duct tape for now.
1 - 16 of 16 Posts
