I have a busted engine mount bolt.
It is the bolt which goes through the mount
into the chassis/bodywork.
The busted off piece is in the chassis.
Has anyone experienced this and how did you rectify
the problem?
I had a similar problem on a 1.8T Jetta; I removed the mount portion that was in the way of the bolt. Luckily, I was able to use a punch to hit the portion of the bolt that was stuck in the threads... I was able to reverse it, remove it. I just replaced it with another bolt; you could use a easy out, if it won't come out easily for you.
There are a number of different styles; some work better then others... hopefully, your may come out easy like mine. If you have a welder; some people, just tack weld a bolt on them... reverse them out as well. Good luck! :)
Here are some examples; most are available from your local hardware or tool store.
https://www.google.com/search?q=eas...sj=1&q=broken+bolt+extractor&sa=N&tab=fw&um=1
Is it the passenger side mount? If so, I bet it wasn't replaced during a timing belt job.
Older but not Wiser
yup yup. happened all the time at the dealership. (not me) we would have come backs for it. be carefull not to strip out the splines, thats a huge important bolt to go back in!!!
good luck!
-jd
I find it kind of ironic that with many of the one time use bolts, I have ALWAYS had to order them from my local dealer.
It seems that they should have plenty of these in stock if they were used often and I know many are cross model compatible, so if the dealer does not stock them, then I can see where they would not likely get replaced on most jobs?
Seems that VW should kit some of these bolts as a single part number to make the parts and techs jobs easier as well??
