I'm looking into adding a little more HP, and was thinking of changing out the stock cam.
I've only found 3 options so far...
1)Neuspeed .429"/256 grind $262.00
2)Autotech .421/.409' 260/256 $159.95
3)Autotech .449"/270 grind $159.95
1)Pros: well know name, will run on ECU upgrade Cons: $100 more than others
2)Pros: Price, will run on Neuspeed ECU upgrade Cons: 1 step higher than a G60 grind
3) Pros: Price, good grind for mid range Cons: not sure about ECU program
Engine specs:
2.0L with 40-50k on rebuild
Neuspeed Supercharger
Pulleyboys 2.6" pulley
ABD Big Bore intake
Neuspeed P-Flow
Neuspeed P-chip ECU
Neuspeed (Tectonics) Stainless exhaust
Any suggestions? Getting ready to do a WP/Belt change and want to do it all at once.
big poster turned lurker.
Have you looked at Techtonics? Their cams are pretty hard to beat, and you can't go wrong with a company people have praised for 8v cams since the mk1 gti.
check them out.
8v Hydraulic Camshafts : Techtonics Tuning
Also, If you do go above a 260 cam, it's highly recommended that you get heavier duty dual valve springs and the accompanying spring seats.
http://www.techtonicstuning.com/main/index.php?main_page=product_info&cPath=2_14_101_427_127&products_id=123&zenid=96e07330449133665b00cea338b125ef
and that goes for all cams, not just Techtonics ones.
