Here's the Acrobat pdf file: http://www.chickenfriedsteak.org/01m.pdffohveh said:I need someone familiar with automatic transmission fluid replacement to do a "how to" on it. Mine needs it asap and I don't know how to go about it.2002 1.8t, Thanks.
3 liters should be plenty - but get 4 to be safe - shipping is about the same... best price I found on Pentosin was www.worldimpex.com for $9 per liter.fohveh said:How much fluid do I buy for the change?? Has anyone just measured out the fluid that came out instead of doing the temperature method for volume to put back in?? If said amount comes out isn't that the same amount to put back and be done with it??
