1 - 11 of 11 Posts
What problems are you having, is the top working and are there, any trouble codes?
We have seen wiring harness issues, bad parts, etc; bring down the bus communication.
Any history on this car; changes or repairs made, etc?
Both front harnesses have been removed from doors & inspected, convenience module replaced, roof does not work. On the canbus wires I have a negative on both wires, will actually light a test lamp
In this code, they are mentioning the door modules and the comfort control module, bringing the bus down.
Good video; going over vw comm bus systems and how they work, diagnostics:
Based upon the video: can bus was implemented later and the 1998-2010 new beetle models, use the older k-line?
Looks like CAN bus, was implemented; on the last 2012+ Beetle models.
If you have vcds; you can check the bus communications bus status (up or down). Because a failed part or module can bring down the bus; you might try checking the bus status and unplug each module or part, recheck the bus status. This maybe a possibly effective, process of elimination; if, when, the bus comes back up, after something is disconnected, that maybe the offending part.
Common issues we have seen; that kills power/functionality, is bad parts, incorrect incompatible parts installed (typically used; junk yard parts) and broken wires, at the flex areas (from the body to the door; in a ribbed rubber sheath).
VW wiring diagrams, can be a bit confusing to read; redrawn simplified versions, can be viewed through AllData and the Mitchell1 service info online.
For free downloadable VW eRWin service manuals; you might check here:
Online manuals:
1 - 11 of 11 Posts
