The car dies when the drivers door is opened with the car idling. I drove it a few times last winter. I would start it and get out while it warmed up. Anyone know what is causing this? I replaced the door latch. It did not correct the problem. It is a 2000 1.8t
door control module
Thanks for the reply vette, I read the post you refered to before I replaced the lock module. I misunderstood. I thought the DLM and the DCM were the same thing. I may have wasted my money on this one. I looked inside the DLM and did not have the solder promlems mentioned in the post. So the DCM could be the problem? How would I diagnose this so I don't waste more money?
The functions can be read with VAG-COM equipment, lacking that, you have to get to the solder connections, visual inspection may reveal the problem, and then they can be checked with a multi-meter. As said, it does sound DCM related, but not sure why the car would die when the door is opened (many strange things result from a bad DCM). Is there any mention of same in the Vortex thread I linked? I haven't read it in months and months.
M.
I have a similar problem. I changed my fuel pump relay and then my car dies when the door is opened and will not start if the door is open. I switch back to the old one and it works fine.
I think there are issues with a lot of 409 relays out on the market. I also read about the relay being changed and the number not being (didn't understand that). I have a funny feeling this has to do with aftermarket Chinese CRAP!
But, I have to ask. If the old one works, why did you change it out? Inquiring minds GOTTA' know!
I hope the OPer sees this, I know opening the door sends a signal to the relay, which in turn pre-primes the fuel pump, but I'm at a loss as to why a bad relay would reverse it's operation and open the fuel pump circuit when the door is open. Obviously what is happening, at least in your case.
M.
409 relay
Vette, thanks for the heads up. I have replaced my relay with one I got from oreilley's. Maybe I have the same problem. Come to think of it, the OE relay had 1 more pin than the replacement. OEM relay on the left. You can see there is a pin missing, upper right of the photo on the right. I believe you are correct about the chinese junk.
Discussion Starter #8 (Edited)
Thread from tdaviscma10
I read the thread from tdaviscma10. In the last sentance of post #06, it reads "Also the part number of the original fuel pump relay is 1J0906383, the new part number is 1J0906383C. The old part had 8 pin and the new one only has 7. I called vw and they said it was superseded and that was the correct an only part I can get."
This is kind of confusing. I think I saved the old relay. I am going to try it. I found the pic of the 8 pin at http://www.autohausaz.com/search/product.aspx?sid=dl4eqijieg5npyapq5pdak45&[email protected]&[email protected] &year=2000&cid=fuel pump [email protected] pump relay&[email protected] Pump Relay. Maybe they still have the OE type. I sent them an email.
http://newbeetle.org/forums/questions-issues-concerns-problems-new-beetle/53034-9-engine-code-ugh.html
