Could be a problem in the wiring. Shorts in the wires in the boot between the driver's door and door frame are known to happen. I assume that "ccm" refers to the comfort module.
So, if you remove fuse 6 you measure battery voltage on both of the fuse contacts? Fuse 6 connects directly to the comfort module.I also have 11 volts running through fuse#6 all the time, not just when I try and use the windows.
