Status
Not open for further replies.
Click here for Ross-Techs Fault code Wiki.
16394- P0010
-A- Camshaft Pos. Actuator Circ. Bank 1 Malfunction
16395- P0020
-A- Camshaft Pos. Actuator Circ. Bank 2 Malfunction
16449- P0065
Air Assisted Injector Control Range/Performance
16450- P0066
Air Assisted Injector Control Low Input/Short to ground
16451- P0067
Air Assisted Injector Control Input/Short to B+
16485- P0101
Mass or Volume Air Flow Circ Range/Performance
16486- P0102
Mass or Volume Air Flow Circ Low Input
16487- P0103
Mass or Volume Air Flow Circ High Input
16489- P0105
Manifold Abs.Pressure or Bar.Pressure Voltage supply
16490- P0106
Manifold Abs.Pressure or Bar.Pressure Range/Performance
16491- P0107
Manifold Abs.Pressure or Bar.Pressure Low Input
16492- P0108
Manifold Abs.Pressure or Bar.Pressure High Input
16496- P0112
Intake Air Temp.Circ Low Input
16497- P0113
Intake Air Temp.Circ High Input
16500- P0116
Engine Coolant Temp.Circ Range/Performance
16501- P0117
Engine Coolant Temp.Circ Low Input
16502- P0118
Engine Coolant Temp.Circ High Input
16504- P0120
Throttle/Pedal Pos.Sensor A Circ Malfunction
16505- P0121
Throttle/Pedal Pos.Sensor A Circ Range/Performance
16506- P0122
Throttle/Pedal Pos.Sensor A Circ Low Input
16507- P0123
Throttle/Pedal Pos.Sensor A Circ High Input
16509- P0125
Insufficient Coolant Temp.for Closed Loop Fuel Control
16512- P0128
Coolant Thermostat/Valve Temperature below control range
16514- P0130
O2 Sensor Circ.,Bank1-Sensor1 Malfunction
16515- P0131
O2 Sensor Circ.,Bank1-Sensor1 Low Voltage
16516- P0132
O2 Sensor Circ.,Bank1-Sensor1 High Voltage
16517- P0133
O2 Sensor Circ.,Bank1-Sensor1 Slow Response
16518- P0134
O2 Sensor Circ.,Bank1-Sensor1 No Activity Detected
16519- P0135
O2 Sensor Heater Circ.,Bank1-Sensor1 Malfunction
16520- P0136
O2 Sensor Circ.,Bank1-Sensor2 Malfunction
16521- P0137
O2 Sensor Circ.,Bank1-Sensor2 Low Voltage
16522- P0138
O2 Sensor Circ.,Bank1-Sensor2 High Voltage
16523- P0139
O2 Sensor Circ.,Bank1-Sensor2 Slow Response
16524- P0140
O2 Sensor Circ.,Bank1-Sensor2 No Activity Detected
16525- P0141
O2 Sensor Heater Circ.,Bank1-Sensor2 Malfunction
16534- P0150
O2 Sensor Circ.,Bank2-Sensor1 Malfunction
16535- P0151
O2 Sensor Circ.,Bank2-Sensor1 Low Voltage
16536- P0152
O2 Sensor Circ.,Bank2-Sensor1 High Voltage
16537- P0153
O2 Sensor Circ.,Bank2-Sensor1 Slow Response
16538- P0154
O2 Sensor Circ.,Bank2-Sensor1 No Activity Detected
16539- P0155
O2 Sensor Heater Circ.,Bank2-Sensor1 Malfunction
16540- P0156
O2 Sensor Circ.,Bank2-Sensor2 Malfunction
16541- P0157
O2 Sensor Circ.,Bank2-Sensor2 Low Voltage
16542- P0158
O2 Sensor Circ.,Bank2-Sensor2 High Voltage
16543- P0159
O2 Sensor Circ.,Bank2-Sensor2 Slow Response
16544- P0160
O2 Sensor Circ.,Bank2-Sensor2 No Activity Detected
16545- P0161
O2 Sensor Heater Circ.,Bank2-Sensor2 Malfunction
16554- P0170
Fuel Trim,Bank1 Malfunction
16555- P0171
Fuel Trim,Bank1 System too Lean
16556- P0172
Fuel Trim,Bank1 System too Rich
16557- P0173
Fuel Trim,Bank2 Malfunction
16558- P0174
Fuel Trim,Bank2 System too Lean
16559- P0175
Fuel Trim,Bank2 System too Rich
16566- P0182
Fuel temperature sender-G81 Short to ground
16567- P0183
Fuel temperature sender-G81 Interruption/Short to B+
16581- P0197
Engine Oil Temperature Circuit Low Input
16582- P0198
Engine Oil Temperature Circuit High Input
16585- P0201
Cyl.1, Injector Circuit Fault in electrical circuit
16586- P0202
Cyl.2, Injector Circuit Fault in electrical circuit
16587- P0203
Cyl.3, Injector Circuit Fault in electrical circuit
16588- P0204
Cyl.4, Injector Circuit Fault in electrical circuit
16589- P0205
Cyl.5 Injector Circuit Fault in electrical circuit
16590- P0206
Cyl.6 Injector Circuit Fault in electrical circuit
16591- P0207
Cyl.7 Injector Circuit Fault in electrical circuit
16592- P0208
Cyl.8 Injector Circuit Fault in electrical circuit
16599- P0215
Engine Shut-Off Solenoid Malfunction
16600- P0216
Injector/Injection Timing Control Malfunction
16603- P0219
Engine Overspeed Condition
16605- P0221
Throttle Pos. Sensor -B- Circuit Range/Performance
16606- P0222
Throttle Pos. Sensor -B- Circuit Low Input
16607- P0223
Throttle Pos. Sensor -B- Circuit High Input
16609- P0225
Throttle Pos. Sensor -C- Circuit Voltage supply
16610- P0226
Throttle Pos. Sensor -C- Circuit Range/Performance
16611- P0227
Throttle Pos. Sensor -C- Circuit Low Input
16612- P0228
Throttle Pos. Sensor -C- Circuit Hight Input
16614- P0230
Fuel Pump Primary Circuit Fault in electrical circuit
16618- P0234
Turbocharger Overboost Condition Control limit exceeded
16619- P0235
Turbocharger Boost Sensor (A) Circ Control limit not reached
16620- P0236
Turbocharger Boost Sensor (A) Circ Range/Performance
16621- P0237
Turbocharger Boost Sensor (A) Circ Low Input
16622- P0238
Turbocharger Boost Sensor (A) Circ High Input
16627- P0243
Turbocharger Wastegate Solenoid (A) Open/Short Circuit to Ground
16629- P0245
Turbocharger Wastegate Solenoid (A) Low Input/Short to ground
16630- P0246
Turbocharger Wastegate Solenoid (A) High Input/Short to B+
16636- P0252
Injection Pump Metering Control (A) Range/Performance
16645- P0261
Cyl.1 Injector Circuit Low Input/Short to ground
16646- P0262
Cyl.1 Injector Circuit High Input/Short to B+
16648- P0264
Cyl.2 Injector Circuit Low Input/Short to ground
16649- P0265
Cyl.2 Injector Circuit High Input/Short to B+
16651- P0267
Cyl.3 Injector Circuit Low Input/Short to ground
16652- P0268
Cyl.3 Injector Circuit High Input/Short to B+
16654- P0270
Cyl.4 Injector Circuit Low Input/Short to ground
16655- P0271
Cyl.4 Injector Circuit High Input/Short to B+
16657- P0273
Cyl.5 Injector Circuit Low Input/Short to ground
16658- P0274
Cyl.5 Injector Circuit High Input/Short to B+
16660- P0276
Cyl.6 Injector Circuit Low Input/Short to ground
16661- P0277
Cyl.6 Injector Circuit High Input/Short to B+
16663- P0279
Cyl.7 Injector Circuit Low Input/Short to ground
16664- P0280
Cyl.7 Injector Circuit High Input/Short to B+
16666- P0282
Cyl.8 Injector Circuit Low Input/Short to ground
16667- P0283
Cyl.8 Injector Circuit High Input/Short to B+
16684- P0300
Random/Multiple Cylinder Misfire Detected
16685- P0301
Cyl.1 Misfire Detected
16686- P0302
Cyl.2 Misfire Detected
16687- P0303
Cyl.3 Misfire Detected
16688- P0304
Cyl.4 Misfire Detected
16689- P0305
Cyl.5 Misfire Detected
16690- P0306
Cyl.6 Misfire Detected
16691- P0307
Cyl.7 Misfire Detected
16692- P0308
Cyl.8 Misfire Detected
16697- P0313
Misfire Detected Low Fuel Level
16698- P0314
Single Cylinder Misfire
16705- P0321
Ign./Distributor Eng.Speed Inp.Circ Range/Performance
16706- P0322
Ign./Distributor Eng.Speed Inp.Circ No Signal
16709- P0325
Knock Sensor 1 Circuit Electrical Fault in Circuit
16710- P0326
Knock Sensor 1 Circuit Range/Performance
16711- P0327
Knock Sensor 1 Circ Low Input
16712- P0328
Knock Sensor 1 Circ High Input
16716- P0332
Knock Sensor 2 Circ Low Input
16717- P0333
Knock Sensor 2 Circ High Input
16719- P0335
Crankshaft Pos. Sensor (A) Circ Malfunction
16720- P0336
Crankshaft Pos. Sensor (A) Circ Range/Performance/Missing tooth
16721- P0337
Crankshaft Pos.Sensor (A) Circ Low Input
16724- P0340
Camshaft Pos. Sensor (A) Circ Incorrect allocation
16725- P0341
Camshaft Pos.Sensor Circ Range/Performance
16726- P0342
Camshaft Pos.Sensor Circ Low Input
16727- P0343
Camshaft Pos.Sensor Circ High Input
16735- P0351
Ignition Coil (A) Cyl.1 Prim./Sec. Circ Malfunction
16736- P0352
Ignition Coil (B) Cyl.2 Prim./Sec. Circ Malfunction
16737- P0353
Ignition Coil © Cyl.3 Prim./Sec. Circ Malfunction
16738- P0354
Ignition Coil (D) Cyl.4 Prim./Sec. Circ Malfunction
16739- P0355
Ignition Coil (E) Cyl.5 Prim./Sec. Circ Malfunction
16740- P0356
Ignition Coil (F) Cyl.6 Prim./Sec. Circ Malfunction
16741- P0357
Ignition Coil (G) Cyl.7 Prim./Sec. Circ Malfunction
16742- P0358
Ignition Coil (H) Cyl.8 Prim./Sec. Circ Malfunction
16764- P0380
Glow Plug/Heater Circuit (A) Electrical Fault in Circuit
16784- P0400
Exhaust Gas Recirc.Flow Malfunction
16785- P0401
Exhaust Gas Recirc.Flow Insufficient Detected
16786- P0402
Exhaust Gas Recirc.Flow Excessive Detected
16787- P0403
Exhaust Gas Recirc. Contr. Circ Malfunction
16788- P0404
Exhaust Gas Recirc. Contr. Circ Range/Performance
16789- P0405
Exhaust Gas Recirc. Sensor (A) Circ Low Input
16790- P0406
Exhaust Gas Recirc. Sensor (A) Circ High Input
16791- P0407
Exhaust Gas Recirc. Sensor (B) Circ Low Input
16792- P0408
Exhaust Gas Recirc. Sensor (B) Circ High Input
16794- P0410
Sec.Air Inj.Sys Malfunction
16795- P0411
Sec.Air Inj.Sys. Incorrect Flow Detected
16796- P0412
Sec.Air Inj.Sys.Switching Valve A Circ Malfunction
16802- P0418
Sec. Air Inj. Sys. Relay (A) Contr. Circ Malfunction
16804- P0420
Catalyst System,Bank1 Efficiency Below Threshold
16806- P0422
Main Catalyst,Bank1 Below Threshold
16811- P0427
Catalyst Temperature Sensor, Bank 1 Low Input/Short to ground
16812- P0428
Catalyst Temperature Sensor, Bank 1 High Input/Open/Short Circuit to B+
16816- P0432
Main Catalyst,Bank2 Efficiency Below Threshold
16820- P0436
Catalyst Temperature Sensor, Bank 2 Range/Performance
16821- P0437
Catalyst Temperature Sensor, Bank 2 Low Input/Short to ground
16822- P0438
Catalyst Temperature Sensor, Bank 2 High Input/Open/Short Circuit to B+
16824- P0440
EVAP Emission Contr.Sys. Malfunction
16825- P0441
EVAP Emission Contr.Sys.Incorrect Purge Flow
16826- P0442
EVAP Emission Contr.Sys.(Small Leak) Leak Detected
16827- P0443
EVAP Emiss. Contr. Sys. Purge Valve Circ Electrical Fault in Circuit
16836- P0452
EVAP Emission Contr.Sys.Press.Sensor Low Input
16837- P0453
EVAP Emission Contr.Sys.Press.Sensor High Input
16839- P0455
EVAP Emission Contr.Sys.(Gross Leak) Leak Detected
16845- P0461
Fuel Level Sensor Circ Range/Performance
16846- P0462
Fuel Level Sensor Circuit Low Input
16847- P0463
Fuel Level Sensor Circuit High Input
16885- P0501
Vehicle Speed Sensor Range/Performance
16887- P0503
Vehicle Speed Sensor Intermittent/Erratic/High Input
16889- P0505
Idle Control System Malfunction
16890- P0506
Idle Control System RPM Lower than Expected
16891- P0507
Idle Control System Higher than Expected
16894- P0510
Closed Throttle Pos.Switch Malfunction
16915- P0531
A/C Refrigerant Pressure Sensor Circuit Range/Performance
16916- P0532
A/C Refrigerant Pressure Sensor Circuit Low Input
16917- P0533
A/C Refrigerant Pressure Sensor Circuit High Input
Discussion Starter · #2 · (Edited)
16935- P0551
Power Steering Pressure Sensor Circuit Range/Performance
16944- P0560
System Voltage Malfunction
16946- P0562
System Voltage Low Voltage
16947- P0563
System Voltage High Voltage
16952- P0568
Cruise Control Set Signal Incorrect Signal
16955- P0571
Cruise/Brake Switch (A) Circ Malfunction
16984- P0600
Serial Comm. Link (Data Bus) Message Missing
16985- P0601
Internal Contr.Module Memory Check Sum Error
16986- P0602
Control Module Programming Error/Malfunction
16987- P0603
Internal Contr.Module (KAM) Error
16988- P0604
Internal Contr.Module Random Access Memory (RAM) Error
16989- P0605
Internal Contr.Module ROM Test Error
16990- P0606
ECM/PCM Processor
17026- P0642
Knock Control Control Module Malfunction
17029- P0645
A/C Clutch Relay Control Circuit
17034- P0650
MIL Control Circuit Electrical Fault in Circuit
17038- P0654
Engine RPM Output Circuit Electrical Fault in Circuit
17040- P0656
Fuel Level Output Circuit Electrical Fault in Circuit
17084- P0700
Transm.Contr.System Malfunction
17086- P0702
Transm.Contr.System Electrical
17087- P0703
Torque Converter/Brake Switch B Circ Malfunction
17089- P0705
Transm.Range Sensor Circ.(PRNDL Inp.) Malfunction
17090- P0706
Transm.Range Sensor Circ Range/Performance
17091- P0707
Transm.Range Sensor Circ Low Input
17092- P0708
Transm.Range Sensor Circ High Input
17094- P0710
Transm.Fluid Temp.Sensor Circ. Malfunction
17095- P0711
Transm.Fluid Temp.Sensor Circ. Range/Performance
17096- P0712
Transm.Fluid Temp.Sensor Circ. Low Input
17097- P0713
Transm.Fluid Temp.Sensor Circ. High Input
17099- P0715
Input Turbine/Speed Sensor Circ. Malfunction
17100- P0716
Input Turbine/Speed Sensor Circ. Range/Performance
17101- P0717
Input Turbine/Speed Sensor Circ. No Signal
17105- P0721
Output Speed Sensor Circ Range/Performance
17106- P0722
Output Speed Sensor Circ No Signal
17109- P0725
Engine Speed Inp.Circ. Malfunction
17110- P0726
Engine Speed Inp.Circ. Range/Performance
17111- P0727
Engine Speed Inp.Circ. No Signal
17114- P0730
Gear Incorrect Ratio
17115- P0731
Gear 1 Incorrect Ratio
17116- P0732
Gear 2 Incorrect Ratio
17117- P0733
Gear 3 Incorrect Ratio
17118- P0734
Gear 4 Incorrect Ratio
17119- P0735
Gear 5 Incorrect Ratio
17124- P0740
Torque Converter Clutch Circ Malfunction
17125- P0741
Torque Converter Clutch Circ Performance or Stuck Off
17132- P0748
Pressure Contr.Solenoid Electrical
17134- P0750
Shift Solenoid A malfunction
17135- P0751
Shift Solenoid A Performance or Stuck Off
17136- P0752
Shift Solenoid A Stuck On
17137- P0753
Shift Solenoid A Electrical
17140- P0756
Shift Solenoid B Performance or Stuck Off
17141- P0757
Shift Solenoid B Stuck On
17142- P0758
Shift Solenoid B Electrical
17145- P0761
Shift Solenoid C Performance or Stuck Off
17146- P0762
Shift Solenoid C Stuck On
17147- P0763
Shift Solenoid C Electrical
17152- P0768
Shift Solenoid D Electrical
17157- P0773
Shift Solenoid E Electrical
17174- P0790
Normal/Performance Switch Circ Malfunction
17509- P1101
O2 Sensor Circ.,Bank1-Sensor1Voltage too Low/Air Leak
17510- P1102
O2 Sensor Heating Circ.,Bank1-Sensor1 Short to B+
17511- P1103
O2 Sensor Heating Circ.,Bank1-Sensor1 Output too Low
17512- P1104
Bank1-Sensor2 Voltage too Low/Air Leak
17513- P1105
O2 Sensor Heating Circ.,Bank1-Sensor2 Short to B+
17514- P1106
O2 Sensor Circ.,Bank2-Sensor1 Voltage too Low/Air Leak
17515- P1107
O2 Sensor Heating Circ.,Bank2-Sensor1 Short to B+
17516- P1108
O2 Sensor Heating Circ.,Bank2-Sensor1 Output too Low
17517- P1109
O2 Sensor Circ.,Bank2-Sensor2 Voltage too Low/Air Leak
17518- P1110
O2 Sensor Heating Circ.,Bank2-Sensor2 Short to B+
17519- P1111
O2 Control (Bank 1) System too lean
17520- P1112
O2 Control (Bank 1) System too rich
17521- P1113
Bank1-Sensor1 Internal Resistance too High
17522- P1114
Bank1-Sensor2 Internal Resistant too High
17523- P1115
O2 Sensor Heater Circ.,Bank1-Sensor1 Short to Ground
17524- P1116
O2 Sensor Heater Circ.,Bank1-Sensor1 Open
17525- P1117
O2 Sensor Heater Circ.,Bank1-Sensor2 Short to Ground
17526- P1118
O2 Sensor Heater Circ.,Bank1-Sensor2 Open
17527- P1119
O2 Sensor Heater Circ.,Bank2-Sensor1 Short to Ground
17528- P1120
O2 Sensor Heater Circ.,Bank2-Sensor1 Open
17529- P1121
O2 Sensor Heater Circ.,Bank2-Sensor2 Short to Ground
17530- P1122
O2 Sensor Heater Circ.,Bank2-Sensor2 Open
17531- P1123
Long Term Fuel Trim Add.Air.,Bank1 System too Rich
17532- P1124
Long Term Fuel Trim Add.Air.,Bank1 System too Lean
17533- P1125
Long Term Fuel Trim Add.Air.,Bank2 System too Rich
17534- P1126
Long Term Fuel Trim Add.Air.,Bank2 System too Lean
17535- P1127
Long Term Fuel Trim mult.,Bank1 System too Rich
17536- P1128
Long Term Fuel Trim mult.,Bank1 System too Lean
17537- P1129
Long Term Fuel Trim mult.,Bank2 System too Rich
17538- P1130
Long Term Fuel Trim mult.,Bank2 System too Lean
17539- P1131
Bank2-Sensor1 Internal Rsistance too High
17540- P1132
O2 Sensor Heating Circ.,Bank1+2-Sensor1 Short to B+
17541- P1133
O2 Sensor Heating Circ.,Bank1+2-Sensor1 Electrical Malfunction
17542- P1134
O2 Sensor Heating Circ.,Bank1+2-Sensor2 Short to B+
17543- P1135
O2 Sensor Heating Circ.,Bank1+2-Sensor2 Electrical Malfunction
17544- P1136
Long Term Fuel Trim Add.Fuel,Bank1 System too Lean
17545- P1137
Long Term Fuel Trim Add.Fuel,Bank1 System too Rich
17546- P1138
Long Term Fuel Trim Add.Fuel,Bank2 System too Lean
17547- P1139
Long Term Fuel Trim Add.Fuel,Bank2 System too Rich
17548- P1140
Bank2-Sensor2 Internal Resistance too High
17549- P1141
Load Calculation Cross Check Range/Performance
17550- P1142
Load Calculation Cross Check Lower Limit Exceeded
17551- P1143
Load Calculation Cross Check Upper Limit Exceeded
17552- P1144
Mass or Volume Air Flow Circ Open/Short to Ground
17553- P1145
Mass or Volume Air Flow Circ Short to B+
17554- P1146
Mass or Volume Air Flow Circ Supply Malfunction
17555- P1147
O2 Control (Bank 2) System too lean
17556- P1148
O2 Control (Bank 2) System too rich
17557- P1149
O2 Control (Bank 1) Out of range
17558- P1150
O2 Control (Bank 2) Out of range
17559- P1151
Bank1, Long Term Fuel Trim, Range 1 Leanness Lower Limit Exceeded
17560- P1152
Bank1, Long Term Fuel Trim, Range 2 Leanness Lower Limit Exceeded
17562- P1154
Manifold Switch Over Malfunction
17563- P1155
Manifold Abs.Pressure Sensor Circ. Short to B+
17564- P1156
Manifold Abs.Pressure Sensor Circ. Open/Short to Ground
17565- P1157
Manifold Abs.Pressure Sensor Circ. Power Supply Malfunction
17566- P1158
Manifold Abs.Pressure Sensor Circ. Range/Performance
17568- P1160
Manifold Temp.Sensor Circ. Short to Ground
17569- P1161
Manifold Temp.Sensor Circ. Open/Short to B+
17570- P1162
Fuel Temp.Sensor Circ. Short to Ground
17571- P1163
Fuel Temp.Sensor Circ. Open/Short to B+
17572- P1164
Fuel Temperature Sensor Range/Performance/Incorrect Signal
17573- P1165
Bank1, Long Term Fuel Trim, Range 1 Rich Limit Exceeded
17574- P1166
Bank1, Long Term Fuel Trim, Range 2 Rich Limit Exceeded
17579- P1171
Throttle Actuation Potentiometer Sign.2 Range/Performance
17580- P1172
Throttle Actuation Potentiometer Sign.2 Signal too Low
17581- P1173
Throttle Actuation Potentiometer Sign.2 Signal too High
17582- P1174
Fuel Trim, Bank 1 Different injection times
17584- P1176
O2 Correction Behind Catalyst,B1 Limit Attained
17585- P1177
O2 Correction Behind Catalyst,B2 Limit Attained
17586- P1178
Linear 02 Sensor / Pump Current Open Circuit
17587- P1179
Linear 02 Sensor / Pump Current Short to ground
17588- P1180
Linear 02 Sensor / Pump Current Short to B+
17589- P1181
Linear 02 Sensor / Reference Voltage Open Circuit
17590- P1182
Linear 02 Sensor / Reference Voltage Short to ground
17591- P1183
Linear 02 Sensor / Reference Voltage Short to B+
17592- P1184
Linear 02 Sensor / Common Ground Wire Open Circuit
17593- P1185
Linear 02 Sensor / Common Ground Wire Short to ground
17594- P1186
Linear 02 Sensor / Common Ground Wire Short to B+
17595- P1187
Linear 02 Sensor / Compens. Resistor Open Circuit
17596- P1188
Linear 02 Sensor / Compens. Resistor Short to ground
17597- P1189
Linear 02 Sensor / Compens. Resistor Short to B+
17598- P1190
Linear 02 Sensor / Reference Voltage Incorrect Signal
17604- P1196
O2 Sensor Heater Circ.,Bank1-Sensor1 Electrical Malfunction
17605- P1197
O2 Sensor Heater Circ.,Bank2-Sensor1 Electrical Malfunction
17606- P1198
O2 Sensor Heater Circ.,Bank1-Sensor2 Electrical Malfunction
17607 P1199
O2 Sensor Heater Circ.,Bank2-Sensor2 Electrical Malfunction
17609 P1201
Cyl.1-Fuel Inj.Circ. Electrical Malfunction
17610 P1202
Cyl.2-Fuel Inj.Circ. Electrical Malfunction
17611 P1203
Cyl.3-Fuel Inj.Circ. Electrical Malfunction
17612 P1204
Cyl.4-Fuel Inj.Circ. Electrical Malfunction
17613 P1205
Cyl.5-Fuel Inj.Circ. Electrical Malfunction
17614 P1206
Cyl.6-Fuel Inj.Circ. Electrical Malfunction
17615 P1207
Cyl.7-Fuel Inj.Circ. Electrical Malfunction
17616 P1208
Cyl.8-Fuel Inj.Circ. Electrical Malfunction
17617 P1209
Intake valves for cylinder shut-off Short circuit to ground
17618 P1210
Intake valves for cylinder shut-off Short to B+
17619 P1211
Intake valves for cylinder shut-off Open circuit
17621 P1213
Cyl.1-Fuel Inj.Circ. Short to B+
17622 P1214
Cyl.2-Fuel Inj.Circ. Short to B+
17623 P1215
Cyl.3-Fuel Inj.Circ. Short to B+
17624 P1216
Cyl.4-Fuel Inj.Circ. Short to B+
17625 P1217
Cyl.5-Fuel Inj.Circ. Short to B+
17626 P1218
Cyl.6-Fuel Inj.Circ. Short to B+
17627 P1219
Cyl.7-Fuel Inj.Circ. Short to B+
17628 P1220
Cyl.8-Fuel Inj.Circ. Short to B+
17629 P1221
Cylinder shut-off exhaust valves Short circuit to ground
17630 P1222
Cylinder shut-off exhaust valves Short to B+
17631 P1223
Cylinder shut-off exhaust valves Open circuit
17633 P1225
Cyl.1-Fuel Inj.Circ. Short to Ground
17634 P1226
Cyl.2-Fuel Inj.Circ. Short to Ground
17635 P1227
Cyl.3-Fuel Inj.Circ. Short to Ground
17636 P1228
Cyl.4-Fuel Inj.Circ. Short to Ground
17637 P1229
Cyl.5-Fuel Inj.Circ. Short to Ground
17638 P1230
Cyl.6-Fuel Inj.Circ. Short to Ground
17639 P1231
Cyl.7-Fuel Inj.Circ. Short to Ground
17640 P1232
Cyl.8-Fuel Inj.Circ. Short to Ground
17645 P1237
Cyl.1-Fuel Inj.Circ. Open Circ.
17646 P1238
Cyl.2-Fuel Inj.Circ. Open Circ.
17647 P1239
Cyl.3-Fuel Inj.Circ. Open Circ.
17648 P1240
Cyl.4-Fuel Inj.Circ. Open Circ.
17649 P1241
Cyl.5-Fuel Inj.Circ. Open Circ.
17650 P1242
Cyl.6-Fuel Inj.Circ. Open Circ.
17651 P1243
Cyl.7-Fuel Inj.Circ. Open Circ.
17652 P1244
Cyl.8-Fuel Inj.Circ. Open Circ.
17653 P1245
Needle Lift Sensor Circ. Short to Ground
17654 P1246
Needle Lift Sensor Circ. Range/Performance
17655 P1247
Needle Lift Sensor Circ. Open/Short to B+
17656 P1248
Injection Start Control Deviation
17657 P1249
Fuel consumption signal Electrical Fault in Circuit
17658 P1250
Fuel Level Too Low
17659 P1251
Start of Injection Solenoid Circ Short to B+
17660 P1252
Start of Injection Solenoid Circ Open/Short to Ground
17661 P1253
Fuel consumption signal Short to ground
17662 P1254
Fuel consumption signal Short to B+
17663 P1255
Engine Coolant Temp.Circ Short to Ground
17664 P1256
Engine Coolant Temp.Circ Open/Short to B+
17665 P1257
Engine Coolant System Valve Open
17666 P1258
Engine Coolant System Valve Short to B+
17667 P1259
Engine Coolant System Valve Short to Ground
17688 P1280
Fuel Inj.Air Contr.Valve Circ. Flow too Low
17691 P1283
Fuel Inj.Air Contr.Valve Circ. Electrical Malfunction
17692 P1284
Fuel Inj.Air Contr.Valve Circ. Open
17693 P1285
Fuel Inj.Air Contr.Valve Circ. Short to Ground
17694 P1286
Fuel Inj.Air Contr.Valve Circ. Short to B+
17695 P1287
Turbocharger bypass valve open
17696 P1288
Turbocharger bypass valve short to B+
17697 P1289
Turbocharger bypass valve short to ground
17704 P1296
Cooling system malfunction
17705 P1297
Connection turbocharger - throttle valve pressure hose
17708 P1300
Misfire detected Reason: Fuel level too low
17721 P1319
Knock Sensor 1 Circ. Short to Ground
17728 P1320
Knock Sensor 2 Circ. Short to Ground
17729 P1321
Knock Sensor 3 Circ. Low Input
17730 P1322
Knock Sensor 3 Circ. High Input
17731 P1323
Knock Sensor 4 Circ. Low Input
17732 P1324
Knock Sensor 4 Circ. High Input
Discussion Starter · #3 · (Edited)
17733 P1325
Cyl.1-Knock Contr. Limit Attained
17734 P1326
Cyl.2-Knock Contr. Limit Attained
17735 P1327
Cyl.3-Knock Contr. Limit Attained
17736 P1328
Cyl.4-Knock Contr. Limit Attained
17737 P1329
Cyl.5-Knock Contr. Limit Attained
17738 P1330
Cyl.6-Knock Contr. Limit Attained
17739 P1331
Cyl.7-Knock Contr. Limit Attained
17740 P1332
Cyl.8-Knock Contr. Limit Attained
17743 P1335
Engine Torque Monitoring 2 Control Limint Exceeded
17744 P1336
Engine Torque Monitoring Adaptation at limit
17745 P1337
Camshaft Pos.Sensor,Bank1 Short to Ground
17746 P1338
Camshaft Pos.Sensor,Bank1 Open Circ./Short to B+
17747 P1339
Crankshaft Pos./Engine Speed Sensor Cross Connected
17748 P1340
Crankshaft-/Camshaft Pos.Sens.Signals Out of Sequence
17749 P1341
Ignition Coil Power Output Stage 1 Short to Ground
17750 P1342
Ignition Coil Power Output Stage 1 Short to B+
17751 P1343
Ignition Coil Power Output Stage 2 Short to Ground
17752 P1344
Ignition Coil Power Output Stage 2 Short to B+
17753 P1345
Ignition Coil Power Output Stage 3 Short to Ground
17754 P1346
Ignition Coil Power Output Stage 3 Short to B+
17755 P1347
Bank2,Crankshaft-/Camshaft os.Sens.Sign. Out of Sequence
17756 P1348
Ignition Coil Power Output Stage 1 Open Circuit
17757 P1349
Ignition Coil Power Output Stage 2 Open Circuit
17758 P1350
Ignition Coil Power Output Stage 3 Open Circuit
17762 P1354
Modulation Piston Displ.Sensor Circ. Malfunction
17763 P1355
Cyl. 1, ignition circuit Open Circuit
17764 P1356
Cyl. 1, ignition circuit Short to B+
17765 P1357
Cyl. 1, ignition circuit Short to ground
17766 P1358
Cyl. 2, ignition circuit Open Circuit
17767 P1359
Cyl. 2, ignition circuit Short Circuit to B+
17768 P1360
Cyl. 2, ignition circuit Short Circuit to Ground
17769 P1361
Cyl. 3, ignition circuit Open Circuit
17770 P1362
Cyl. 3, ignition circuit Short Circuit to B+
17771 P1363
Cyl. 3, ignition circuit Short Circuit to ground
17772 P1364
Cyl. 4 ignition circuit Open Circuit
17773 P1365
Cyl. 4 ignition circuit Short circuit to B+
17774 P1366
Cyl. 4 ignition circuit Short circuit to ground
17775 P1367
Cyl. 5, ignition circuit Open Circuit
17776 P1368
Cyl. 5, ignition circuit Short Circuit to B+
17777 P1369
Cyl. 5, ignition circuit short to ground
17778 P1370
Cyl. 6, ignition circuit Open Circuit
17779 P1371
Cyl. 6, ignition circuit Short Circuit to B+
17780 P1372
Cyl. 6, ignition circuit short to ground
17781 P1373
Cyl. 7, ignition circuit Open Circuit
17782 P1374
Cyl. 7, ignition circuit Short Circuit to B+
17783 P1375
Cyl. 7, ignition circuit short to ground
17784 P1376
Cyl. 8, ignition circuit Open Circuit
17785 P1377
Cyl. 8, ignition circuit Short Circuit to B+
17786 P1378
Cyl. 8, ignition circuit short to ground
17794 P1386
Internal Control Module Knock Control Circ.Error
17795 P1387
Internal Contr. Module altitude sensor error
17796 P1388
Internal Contr. Module drive by wire error
17799 P1391
Camshaft Pos.Sensor,Bank2 Short to Ground
17800 P1392
Camshaft Pos.Sensor,Bank2 Open Circ./Short to B+
17801 P1393
Ignition Coil Power Output Stage 1 Electrical Malfunction
17802 P1394
Ignition Coil Power Output Stage 2 Electrical Malfunction
17803 P1395
Ignition Coil Power Output Stage 3 Electrical Malfunction
17804 P1396
Engine Speed Sensor Missing Tooth
17805 P1397
Engine speed wheel Adaptation limit reached
17806 P1398
Engine RPM signal, TD Short to ground
17807 P1399
Engine RPM signal, TD Short Circuit to B+
17808 P1400
EGR Valve Circ Electrical Malfunction
17809 P1401
EGR Valve Circ Short to Ground
17810 P1402
EGR Valve Circ Short to B+
17811 P1403
EGR Flow Deviation
17812 P1404
EGR Flow Basic Setting not carried out
17814 P1406
EGR Temp.Sensor Range/Performance
17815 P1407
EGR Temp.Sensor Signal too Low
17816 P1408
EGR Temp.Sensor Signal too High
17817 P1409
Tank Ventilation Valve Circ. Electrical Malfunction
17818 P1410
Tank Ventilation Valve Circ. Short to B+
17819 P1411
Sec.Air Inj.Sys.,Bank2 Flow too Flow
17820 P1412
EGR Different.Pressure Sensor Signal too Low
17821 P1413
EGR Different.Pressure Sensor Signal too High
17822 P1414
Sec.Air Inj.Sys.,Bank2 Leak Detected
17825 P1417
Fuel Level Sensor Circ Signal too Low
17826 P1418
Fuel Level Sensor Circ Signal too High
17828 P1420
Sec.Air Inj.Valve Circ Electrical Malfunction
17829 P1421
Sec.Air Inj.Valve Circ Short to Ground
17830 P1422
Sec.Air Inj.Sys.Contr.Valve Circ Short to B+
17831 P1423
Sec.Air Inj.Sys.,Bank1 Flow too Low
17832 P1424
Sec.Air Inj.Sys.,Bank1 Leak Detected
17833 P1425
Tank Vent.Valve Short to Ground
17834 P1426
Tank Vent.Valve Open
17840 P1432
Sec.Air Inj.Valve Open
17841 P1433
Sec.Air Inj.Sys.Pump Relay Circ. open
17842 P1434
Sec.Air Inj.Sys.Pump Relay Circ. Short to B+
17843 P1435
Sec.Air Inj.Sys.Pump Relay Circ. Short to ground
17844 P1436
Sec.Air Inj.Sys.Pump Relay Circ. Electrical Malfunction
17847 P1439
EGR Potentiometer Error in Basic Seting
17848 P1440
EGR Valve Power Stage Open
17849 P1441
EGR Valve Circ Open/Short to Ground
17850 P1442
EGR Valve Position Sensor Signal too high
17851 P1443
EGR Valve Position Sensor Signal too low
17852 P1444
EGR Valve Position Sensor range/performance
17853 P1445
Catalyst Temp.Sensor 2 Circ. Range/Performance
17854 P1446
Catalyst Temp.Circ Short to Ground
17855 P1447
Catalyst Temp.Circ Open/Short to B+
17856 P1448
Catalyst Temp.Sensor 2 Circ. Short to Ground
17857 P1449
Catalyst Temp.Sensor 2 Circ. Open/Short to B+
17858 P1450
Sec.Air Inj.Sys.Circ Short to B+
17859 P1451
Sec.Air Inj.Sys.Circ Short to Ground
17860 P1452
Sec.Air Inj.Sys. Open Circ.
17861 P1453
Exhaust gas temperature sensor 1 open/short to B+
17862 P1454
Exhaust gas temperature sensor short 1 to ground
17863 P1455
Exhaust gas temperature sensor 1 range/performance
17864 P1456
Exhaust gas temperature control bank 1 limit attained
17865 P1457
Exhaust gas temperature sensor 2 open/short to B+
17866 P1458
Exhaust gas temperature sensor 2 short to ground
17867 P1459
Exhaust gas temperature sensor 2 range/performance
17868 P1460
Exhaust gas temperature control bank 2 limit attained
17869 P1461
Exhaust gas temperature control bank 1 Range/Performance
17870 P1462
Exhaust gas temperature control bank 2 Range/Performance
17873 P1465
Additive Pump Short Circuit to B+
17874 P1466
Additive Pump Open/Short to Ground
17875 P1467
EVAP Canister Purge Solenoid Valve Short Circuit to B+
17876 P1468
EVAP Canister Purge Solenoid Valve Short Circuit to Ground
17877 P1469
EVAP Canister Purge Solenoid Valve Open Circuit
17878 P1470
EVAP Emission Contr.LDP Circ Electrical Malfunction
17879 P1471
EVAP Emission Contr.LDP Circ Short to B+
17880 P1472
EVAP Emission Contr.LDP Circ Short to Ground
17881 P1473
EVAP Emission Contr.LDP Circ Open Circ.
17882 P1474
EVAP Canister Purge Solenoid Valve electrical malfunction
17883 P1475
EVAP Emission Contr.LDP Circ Malfunction/Signal Circ.Open
17884 P1476
EVAP Emission Contr.LDP Circ Malfunction/Insufficient Vacuum
17885 P1477
17886 P1478
EVAP Emission Contr.LDP Circ Clamped Tube Detected
17908 P1500
Fuel Pump Relay Circ. Electrical Malfunction
17909 P1501
Fuel Pump Relay Circ. Short to Ground
17910 P1502
Fuel Pump Relay Circ. Short to B+
17911 P1503
Load signal from Alternator Term. DF Range/performance/Incorrect Signal
17912 P1504
Intake Air Sys.Bypass Leak Detected
17913 P1505
Closed Throttle Pos. Does Not Close/Open Circ
17914 P1506
Closed Throttle Pos.Switch Does Not Open/Short to Ground
17915 P1507
Idle Sys.Learned Value Lower Limit Attained
17916 P1508
Idle Sys.Learned Value Upper Limit Attained
17917 P1509
Idle Air Control Circ. Electrical Malfunction
17918 P1510
Idle Air Control Circ. Short to B+
17919 P1511
Intake Manifold Changeover Valve circuit electrical malfunction
17920 P1512
Intake Manifold Changeover Valve circuit Short to B+
17921 P1513
Intake Manifold Changeover Valve2 circuit Short to B+
17922 P1514
Intake Manifold Changeover Valve2 circuit Short to ground
17923 P1515
Intake Manifold Changeover Valve circuit Short to Ground
17924 P1516
Intake Manifold Changeover Valve circuit Open
17925 P1517
Main Relay Circ. Electrical Malfunction
17926 P1518
Main Relay Circ. Short to B+
17927 P1519
Intake Camshaft Contr.,Bank1 Malfunction
17928 P1520
Intake Manifold Changeover Valve2 circuit Open
17929 P1521
Intake Manifold Changeover Valve2 circuit electrical malfunction
17930 P1522
Intake Camshaft Contr.,Bank2 Malfunction
17931 P1523
Crash Signal from Airbag Control Unit range/performance
17933 P1525
Intake Camshaft Contr.Circ.,Bank1 Electrical Malfunction
17934 P1526
Intake Camshaft Contr.Circ.,Bank1 Short to B+
17935 P1527
Intake Camshaft Contr.Circ.,Bank1 Short to Ground
17936 P1528
Intake Camshaft Contr.Circ.,Bank1 Open
17937 P1529
Camshaft Control Circuit Short to B+
17938 P1530
Camshaft Control Circuit Short to ground
17939 P1531
Camshaft Control Circuit open
17941 P1533
Intake Camshaft Contr.Circ.,Bank2 Electrical Malfunction
17942 P1534
Intake Camshaft Contr.Circ.,Bank2 Short to B+
17943 P1535
Intake Camshaft Contr.Circ.,Bank2 Short to Ground
17944 P1536
Intake Camshaft Contr.Circ.,Bank2 Open
17945 P1537
Engine Shutoff Solenoid Malfunction
17946 P1538
Engine Shutoff Solenoid Open/Short to Ground
17947 P1539
Clutch Vacuum Vent Valve Switch Incorrect signal
17948 P1540
Vehicle Speed Sensor High Input
17949 P1541
Fuel Pump Relay Circ Open
17950 P1542
Throttle Actuation Potentiometer Range/Performance
17951 P1543
Throttle Actuation Potentiometer Signal too Low
17952 P1544
Throttle Actuation Potentiometer Signal too High
17953 P1545
Throttle Pos.Contr Malfunction
17954 P1546
Boost Pressure Contr.Valve Short to B+
17955 P1547
Boost Pressure Contr.Valve Short to Ground
17956 P1548
Boost Pressure Contr.Valve Open
17957 P1549
17958 P1550
Charge Pressure Deviation
17959 P1551
Barometric Pressure Sensor Circ. Short to B+
17960 P1552
Barometric Pressure Sensor Circ. Open/Short to Ground
17961 P1553
Barometric/manifold pressure signal ratio out of range
17962 P1554
Idle Speed Contr.Throttle Pos. Basic Setting Conditions not met
17963 P1555
Charge Pressure Upper Limit exceeded
17964 P1556
Charge Pressure Contr. Negative Deviation
17965 P1557
Charge Pressure Contr. Positive Deviation
17966 P1558
Throttle Actuator Electrical Malfunction
17967 P1559
Idle Speed Contr.Throttle Pos. Adaptation Malfunction
17968 P1560
Maximum Engine Speed Exceeded
Discussion Starter · #4 · (Edited)
17969 P1561
Quantity Adjuster Deviation
17970 P1562
Quantity Adjuster Upper Limit Attained
17971 P1563
Quantity Adjuster Lower Limit Attained
17972 P1564
Idle Speed Contr.Throttle Pos. Low Voltage During Adaptation
17973 P1565
Idle Speed Control Throttle Position lower limit not attained
17974 P1566
Load signal from A/C compressor range/performance
17975 P1567
Load signal from A/C compressor no signal
17976 P1568
Idle Speed Contr.Throttle Pos. mechanical Malfunction
17977 P1569
Cruise control switch Incorrect signal
17978 P1570
Contr.Module Locked
17979 P1571
Left Eng. Mount Solenoid Valve Short to B+
17980 P1572
Left Eng. Mount Solenoid Valve Short to ground
17981 P1573
Left Eng. Mount Solenoid Valve Open circuit
17982 P1574
Left Eng. Mount Solenoid Valve Electrical fault in circuit
17983 P1575
Right Eng. Mount Solenoid Valve Short to B+
17984 P1576
Right Eng. Mount Solenoid Valve Short to ground
17985 P1577
Right Eng. Mount Solenoid Valve Open circuit
17986 P1578
Right Eng. Mount Solenoid Valve Electrical fault in circuit
17987 P1579
Idle Speed Contr.Throttle Pos. Adaptation not started
17988 P1580
Throttle Actuator B1 Malfunction
17989 P1581
Idle Speed Contr.Throttle Pos. Basic Setting Not Carried Out
17990 P1582
Idle Adaptation at Limit
17991 P1583
Transmission mount valves Short to B+
17992 P1584
Transmission mount valves Short to ground
17993 P1585
Transmission mount valves Open circuit
17994 P1586
Engine mount solenoid valves Short to B+
17995 P1587
Engine mount solenoid valves Short to ground
17996 P1588
Engine mount solenoid valves Open circuit
18008 P1600
Power Supply (B+) Terminal 15 Low Voltage
18010 P1602
Power Supply (B+) Terminal 30 Low Voltage
18011 P1603
Internal Control Module Malfunction
18012 P1604
Internal Control Module Driver Error
18013 P1605
Rough Road/Acceleration Sensor Electrical Malfunction
18014 P1606
Rough Road Spec Engine Torque ABS-ECU Electrical Malfunction
18015 P1607
Vehicle speed signal Error message from instrument cluster
18016 P1608
Steering angle signal Error message from steering angle sensor
18017 P1609
Crash shut-down activated
18019 P1611
MIL Call-up Circ./Transm.Contr.Module Short to Ground
18020 P1612
Electronic Control Module Incorrect Coding
18021 P1613
MIL Call-up Circ Open/Short to B+
18022 P1614
MIL Call-up Circ./Transm.Contr.Module Range/Performance
18023 P1615
Engine Oil Temperature Sensor Circuit range/performance
18024 P1616
Glow Plug/Heater Indicator Circ. Short to B+
18025 P1617
Glow Plug/Heater Indicator Circ. Open/Short to Ground
18026 P1618
Glow Plug/Heater Relay Circ. Short to B+
18027 P1619
Glow Plug/Heater Relay Circ. Open/Short to Ground
18028 P1620
Engine coolant temperature signal open/short to B+
18029 P1621
Engine coolant temperature signal short to ground
18030 P1622
Engine coolant temperature signal range/performance
18031 P1623
Data Bus Powertrain No Communication
18032 P1624
MIL Request Sign.active
18033 P1625
Data-Bus Powertrain Unplausible Message from Transm.Contr.
18034 P1626
Data-Bus Powertrain Missing Message from Transm.Contr.
18035 P1627
Data-Bus Powertrain missing message from fuel injection pump
18036 P1628
Data-Bus Powertrain missing message from steering sensor
18037 P1629
Data-Bus Powertrain missing message from distance control
18038 P1630
Accelera.Pedal Pos.Sensor 1 Signal too Low
18039 P1631
Accelera.Pedal Pos.Sensor 1 Signal too High
18040 P1632
Accelera.Pedal Pos.Sensor 1 Power Supply Malfunction
18041 P1633
Accelera.Pedal Pos.Sensor 2 Signal too Low
18042 P1634
Accelera.Pedal Pos.Sensor 2 Signal too High
18043 P1635
Data Bus Powertrain missing message f.air condition control
18044 P1636
Data Bus Powertrain missing message from Airbag control
18045 P1637
Data Bus Powertrain missing message f.central electr.control
18046 P1638
Data Bus Powertrain missing message from clutch control
18047 P1639
Accelera.Pedal Pos.Sensor 1+2 Range/Performance
18048 P1640
Internal Contr.Module (EEPROM) Error
18049 P1641
Please check DTC Memory of Air Condition ECU
18050 P1642
Please check DTC Memory of Airbag ECU
18051 P1643
Please check DTC Memory of central electric ECU
18052 P1644
Please check DTC Memory of clutch ECU
18053 P1645
Data Bus Powertrain missing message f.all wheel drive contr.
18054 P1646
Please Check DTC Memory of all wheel drive ECU
18055 P1647
Please check coding of ECUs in Data Bus Powertrain
18056 P1648
Data Bus Powertrain Malfunction
18057 P1649
Data Bus Powertrain Missing message from ABS Control Module
18058 P1650
Data Bus Powertrain Missing message fr.instrument panel ECU
18059 P1651
Data Bus Powertrain missing messages
18060 P1652
Please check DTC Memory of transmission ECU
18061 P1653
Please check DTC Memory of ABS Control Module
18062 P1654
Please check DTC Memory of control panel ECU
18063 P1655
Please check DTC Memory of ADR Control Module
18064 P1656
A/C clutch relay circuit short to ground
18065 P1657
A/C clutch relay circuit short to B+
18066 P1658
Data Bus Powertrain Incorrect signal from ADR Control Module
18084 P1676
Drive by Wire-MIL Circ. Electrical Malfunction
18085 P1677
Drive by Wire-MIL Circ. Short to B+
18086 P1678
Drive by Wire-MIL Circ. Short to Ground
18087 P1679
Drive by Wire-MIL Circ. Open
18089 P1681
Contr.Unit Programming, Programming not Finished
18092 P1684
Contr.Unit Programming Communication Error
18094 P1686
Contr.Unit Error Programming Error
18098 P1690
Malfunction Indication Light Malfunction
18099 P1691
Malfunction Indication Light Open
18100 P1692
Malfunction Indication Light Short to Ground
18101 P1693
Malfunction Indication Light Short to B+
18102 P1694
Malfunction Indication Light Open/Short to Ground
18112 P1704
Kick Down Switch Malfunction
18113 P1705
Gear/Ratio Monitoring Adaptation limit reached
18119 P1711
Wheel Speed Signal 1 Range/Performance
18124 P1716
Wheel Speed Signal 2 Range/Performance
18129 P1721
Wheel Speed Signal 3 Range/Performance
18131 P1723
Starter Interlock Circ. Open
18132 P1725
Starter Interlock Circ. Short to Ground
18134 P1726
Wheel Speed Signal 4 Range/Performance
18136 P1728
Different Wheel Speed Signals Range/Performance
18137 P1729
Starter Interlock Circ. Short to B+
18141 P1733
Tiptronic Switch Down Circ. Short to Ground
18147 P1739
Tiptronic Switch up Circ. Short to Ground
18148 P1740
Clutch temperature control
18149 P1741
Clutch pressure adaptation at limit
18150 P1742
Clutch torque adaptation at limit
18151 P1743
Clutch slip control signal too high
18152 P1744
Tiptronic Switch Recognition Circ. Short to Ground
18153 P1745
Transm.Contr.Unit Relay Short to B+
18154 P1746
Transm.Contr.Unit Relay Malfunction
18155 P1747
Transm.Contr.Unit Relay Open/Short to Ground
18156 P1748
Transm.Contr.Unit Self-Check
18157 P1749
Transm.Contr.Unit Incorrect Coded
18158 P1750
Power Supply Voltage Low Voltage
18159 P1751
Power Supply Voltage High Voltage
18160 P1752
18168 P1760
Shift Lock Malfunction
18169 P1761
Shift Lock Short to Ground
18170 P1762
Shift Lock Short to B+
18171 P1763
Shift Lock Open
18172 P1764
Transmission temperature control
18173 P1765
Hydraulic Pressure Sensor 2 adaptation at limit
18174 P1766
Throttle Angle Signal Stuck Off
18175 P1767
Throttle Angle Signal Stuck On
18176 P1768
Hydraulic Pressure Sensor 2 Too High
18177 P1769
Hydraulic Pressure Sensor 2 Too Low
18178 P1770
Load Signal Range/Performance
18179 P1771
Load Signal Stuck Off
18180 P1772
Load Signal Stuck On
18181 P1773
Hydraulic Pressure Sensor 1 Too High
18182 P1774
Hydraulic Pressure Sensor 1 Too Low
18183 P1775
Hydraulic Pressure Sensor 1 adaptation at limit
18184 P1776
Hydraulic Pressure Sensor 1 range/performance
18185 P1777
Hydraulic Pressure Sensor 2 range/performance
18186 P1778
Solenoid EV7 Electrical Malfunction
18189 P1781
Engine Torque Reduction Open/Short to Ground
18190 P1782
Engine Torque Reduction Short to B+
18192 P1784
Shift up/down Wire Open/Short to Ground
18193 P1785
Shift up/down Wire Short to B+
18194 P1786
Reversing Light Circ. Open
18195 P1787
Reversing Light Circ. Short to Ground
18196 P1788
Reversing Light Circ. Short to B+
18197 P1789
Idle Speed Intervention Circ. Error Message from Engine Contr.
18198 P1790
Transmission Range Display Circ. Open
18199 P1791
Transmission Range Display Circ. Short to Ground
18200 P1792
Transmission Range Display Circ. Short to B+
18201 P1793
Output Speed Sensor 2 Circ. No Signal
18203 P1795
Vehicle Speed Signal Circ. Open
18204 P1796
Vehicle Speed Signal Circ. Short to Ground
18205 P1797
Vehicle Speed Signal Circ. Short to B+
18206 P1798
Output Speed Sensor 2 Circ. Range/Performance
18207 P1799
Output Speed Sensor 2 Circ. Rpm too High
18221 P1813
Pressure Contr.Solenoid 1 Electrical
18222 P1814
Pressure Contr.Solenoid 1 Open/Short to Ground
18223 P1815
Pressure Contr.Solenoid 1 Short to B+
18226 P1818
Pressure Contr.Solenoid 2 Electrical
18227 P1819
Pressure Contr.Solenoid 2 Open/Short to Ground
18228 P1820
Pressure Contr.Solenoid 2 Short to B+
18231 P1823
Pressure Contr.Solenoid 3 Electrical
18232 P1824
Pressure Contr.Solenoid 3 Open/Short to Ground
18233 P1825
Pressure Contr.Solenoid 3 Short to B+
18236 P1828
Pressure Contr.Solenoid 4 Electrical
18237 P1829
Pressure Contr.Solenoid 4 Open/Short to Ground
18238 P1830
Pressure Contr.Solenoid 4 Short to B+
18242 P1834
Pressure Contr.Solenoid 5 Open/Short to Ground
18243 P1835
Pressure Contr.Solenoid 5 Short to B+
18249 P1841
Engine/Transmission Control Modules Versions do not match
18250 P1842
Please check DTC Memory of instrument panel ECU
18251 P1843
18252 P1844
Please check DTC Memory of central electric control ECU
18255 P1847
Please check DTC Memory of brake system ECU
18256 P1848
Please check DTC Memory of engine ECU
18257 P1849
18258 P1850
Data-Bus Powertrain Missing Message from Engine Contr.
18259 P1851
Data-Bus Powertrain Missing Message from Brake Contr.
18260 P1852
Data-Bus Powertrain Unplausible Message from Engine Contr.
18261 P1853
Data-Bus Powertrain Unplausible Message from Brake Contr.
18262 P1854
Data-Bus Powertrain Hardware Defective
18263 P1855
Data-Bus Powertrain Software version Contr.
18264 P1856
Throttle/Pedal Pos.Sensor A Circ. Error Message from Engine Contr.
18265 P1857
Load Signal Error Message from Engine Contr.
18266 P1858
Engine Speed Input Circ. Error Message from Engine Contr.
18267 P1859
Brake Switch Circ. Error Message from Engine Contr.
18268 P1860
Kick Down Switch Error Message from Engine Contr.
18269 P1861
Throttle Position (TP) sensor Error Message from ECM
18270 P1862
Data Bus Powertrain Missing message from instr. panel ECU
18271 P1863
Data Bus Powertrain Missing Message from St. Angle Sensor
18272 P1864
Data Bus Powertrain Missing message from ADR control module
18273 P1865
Data Bus Powertrain Missing message from central electronics
18274 P1866
Data Bus Powertrain Missing messages
Status
