Did the first oil changed on my daughter's bug. Filled with 6 qts 5w-40 of Castrol full syn with Purolator filter. Now the check engine light is on.
The only thing I can figure is that I checked the oil level with the engine running. When I pulled the dip stick out i could hear air suck in or out and the engine started to shake a little. I'm guessing that's not recommended?
Anyway, can I just reset the check engine light myself? If so, how do I do that?
Thanks.
Thanks.
