"Flippin Sweet"
Do you get just as good reception with a short antenna as with a long one? If so, why don't they all come with short ones?
Are some better than others or should I get anything that says
will fit New Beetle?
Thanks.
I've heard that some people don't get as good reception with the shorter antennas. I haven't noticed any difference with mine, compared to stock.
There are some antennas that have a bit of a better fit than others. The S2000 antenna will fit (screws right in), however, the base of the antenna is a little bigger than the base it screws into, so you see a slight difference.
The enfig motorsports antenna has the same look as the S2000, but matches up better.
Available here
Do you have any better pictures of the enfig antenna? I'd like to see the whole thing on the car not just the base. The S2000 is just slightly bigger than the enfig, it doesn't matter to me that much. I was actually about to post a thread like this....;)
