An Air-Cooled Fan, Too!
Myself and a friend, who used to do tune ups on an old dual-carb type III squareback years ago, tried to change the plugs on my '99 2.0 today and couldn't do it! The two inner plugs are completely covered by the intake manifold and we couldn't see how to even remove the rubber plug covers much less remove and replace the plugs themselves. I'm sure some of you on this forum have probably done this yourselves, but how (w/o removing the intake manifold first?) :(
big poster turned lurker.
I'm not mechanically inclined (although electronically inclined) and i had no problem doin my plugs, other than breaking my coil pack. All u need to get at the 2 inner plugs is a long extension for the ratchet (or 2 or 3). The plugs are angled just so, that theyre removeable without taking the intake manifold off.
I didn't really care about the wires, so i just yanked em off, cuz i got some sweet 8.5 mm magnacor's to install, and it was a bit of a guess as to weather i seated the inner plug wires right, but the car's been perfect for a few months now, so i guess i did it right.
180 Degrees out of faze
The wires are very tender, and if not removed carefully, they will fail. Use a plug wire puller. If you have new wires, they just give them a good yank. To get better access to the inner two plugs, carefully rotate the fuel injector about 90 degrees to get the connectors out of the way.
OG Stalker
I have small hands and wrists. Now with that said, the first time around I did break a plug wire. They are extremely delicate and will crack easily causing the car to misfire.
