Hello everybody. New here and wondering if here is somebody how can look at some logs I've made from the 1.8T. I'm getting sometimes a 17705 code but no CEL. Every help is welkom!!
If you have logs, feel free to post on up. And its perfectly normal to have codes without the CEL. Lots of codes can be thrown without triggering that.
Info on the 17705 code:
17705/P1297/004759 - Ross-Tech Wiki
17705/P1297/004759 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Power Loss
Possible Causes
Leaking Hoses and/or Pipes between Components
Boost Pressure Control Valve (N249) faulty
Diverter Valve faulty
Throttle Body dirty
Possible Solutions
Check Hoses and Pipes between Components
Check / Replace Boost Pressure Control Valve (N249)
Check / Replace Diverter Valve
Check / Clean Throttle Body
Perform Throttle Body Alignment
He who walks on Ice!
When I had this code pop up, it was a vacuum hose!!! Yeah, a simple connection like that. lol...but, the most common problem is the diverter.
I've already changed the DV for a Forge08. What channels should I log for searching this code? How can I check the N249 valve? Greatings from Holland.
Stuart
I'd start by checking your hoses and making sure you don't have any leaks. Not sure you really need to log anything at this point.
Don't do a log just yet, do a run through. Since we know that it's a turbo...any air parameters outside of stock will throw this code. Look at all connections (any pressure hose). After you do that, then it's time to dive into the sensors.
