Hey guys,
I am going to replace the automatic transmission fluid and filter on my 2002 2.0 and since the fluid level checking procedure say the oil has to be between 35C to 45 (95 to 113F) I want to know if the OBD FUSION APP can tell me the temperature.
I also have VAG COM LITE on free version, can I check the temperature of the transmission oil on the VAG COM LITE free version?
THX,
Isaac
FLUID LEVEL CHECKING PROCEDURE
Now start the car and go into the transmissions data blocks under transmission with
your VAG-Com and go to block 005, this will display fluid temp.
-ATF temperature not above approx. 30C (86F)
-Vehicle level
-Selector lever in "P"
-If ATF is below 30C (86F) bring the ATF up to test temperature.
Test temperature: 35C to 45 (95 to 113F)
-Remove ATF level plug from oil pan.
If ATF drips out of hole:
ATF need not be topped up.
-Install new seal on plug and tighten to 15 Nm11 ft lb).
ATF check is completed.
If ATF does not drip out
-Remove plug from filler line.
-Fill with ATF until ATF runs out of level hole
-Install new seal on plug and tighten to 15 Nm (11 ft lb).
THX,
Isaac
-Vehicle level
