1 - 1 of 1 Posts
beetle 1998 2.0l aeg automatic trans.
When I drive the car slower than 60mph, everything is perfect.
When I drive the car faster than 65~~.. mph, cluster speed needle is shaking
65~70(kinda jumping around between 65~70).
I ve searched a lot of article about it and I find it may be caused by cluster or vss.
What you guys recommend to change at first?
When I connect with my vag com cable, I only can find a code,
17584 - bank1: 02 (lamda) correction behind catalyst: control limit reached
p1176 - 35 - 00 - -
readiness: 0000 0100.
I don't think this code is related with the symptom.
Any idea how can I find out whether cluster or vss?
And.. I know how to replace cluster but vss.
I ve searched for that but no luck.
I found automatic beetle has 3 vss on trans BUT I don't know where they are located and
I don't know how to find out one vss that is caused the problem.
Moreover, for the code, I ve searched, it may be caused by MAF or O2 or temperature sensor or
throttle body.
It's too much to replace them all. Any idea for that?
1 - 1 of 1 Posts
