This might be a little long winded.......I have a 2012 Beetle Turbo. The clutch went out (completely burned up, only have clutch material on one side of the disc). Replaced the clutch, slave cylinder, along with a new dual mass flywheel. Bled the system and after driving it approximately 1 mile, come to a stop and then it will not go in to gear. I can pump the clutch a few times & then it will be fine for another 3/4 mile or so. Bled the clutch more, & more & more = Same result.
Replaced the master cylinder & bled the system - same thing. I just, today, replaced the hydraulic line & the bleeder block - no change at all.
I have bled this thing probably 2 dozen times (manually, gravity bleeding & even following the OE instructions with pressure bleeding the system multiple times)....To no avail. I have no idea what to do next. Any help would be greatly appreciated!!
