I'm a long time VW owner and have replaced many clutches on old beetles, rabbit's and sciroccos. My wife's NB is an 04 NB 1.8 Turbo Convertible. I can say, I've never seen a Volkswagen quite so hard to work on. After an hour of disassembly and getting the battery and air cleaner out, finally got to see what I needed to do and almost made it but had to stop....
Here is the problem (beside the fact that my tool box was missing a 16MM socket and box end, 5/8 is close enough...) I could not get the transmission to clear the left side of the car. I had jacks on both the engine and transmission but it would not go down far enough to slide it out.
I believe my problem might be that I did not disconnect the exhaust. Has anyone done this before???? Any way, bolted it back up and went to bed to sleep on it. Back at it tonight.
