Just got a set of codes. All showing short to ground. Cleared and haven't come back. Weird. 17536,17633,634,635,636,859, 829,833,880, and 16826. Car runs perfectly. Any ideas what I should look for?
I had this same issue and for $32 I ordered the fuse junction (on top of the battery) replacing the 3 30amp fuses with a 20, 30 and 40.Just got a set of codes. All showing short to ground. Cleared and haven't come back. Weird. 17536,17633,634,635,636,859, 829,833,880, and 16826. Car runs perfectly. Any ideas what I should look for?
It DOES just replace the fuse box on top of the battery. I found it at Rock Auto online store.Thanks Chris. I suspected a single stupid fix would take care of it since I've never had problems with this car. Where did you get this part and does it just replace that fuse thing on top of the battery?
I got 3 for the same reason. The second one fixed a slew of issues in my son's 2001 Jetta GLX with the VR6. He had similar codes AND had issues with his AC.WOW, that is a good find. The dealer wants 135 bucks for that part and Rock Auto only 33 and change. I may order one just in case.Thanks for the link!
Thanks so much Chris. I have another question though. I looked at the fuse block on top of the battery and it looks like new. What exactly am I looking for? Everything looks and all connections look pristine. Could this be a problem with one of the main cables?...Or is it a problem that doesn't always make that block look bad or corroded?It DOES just replace the fuse box on top of the battery. I found it at Rock Auto online store.
I suspect you had the same thing that I and a LOT of others found - and that is corrosion on the connections. I took mine apart afterwords and there was additional corrosion internally. But I believe the biggest issue is the power distribution itself and the proper use of the 90 amps.
Best of luck! Please let me know if you need anything else!
BTW - here is where I found it RockAuto Parts Catalog , and use the link for "Fuse Box" NOT the "Power Distribution Block", unless you LIKE paying double for the same thing. My ONLY additional suggestion is replacing the 3 30amp fuses with a 20, 30 and a 40.
Chris
Another area you may want to check is your ignition switch. It can throw a bunch of codes when it stars failing.Thanks so much Chris. I have another question though. I looked at the fuse block on top of the battery and it looks like new. What exactly am I looking for? Everything looks and all connections look pristine. Could this be a problem with one of the main cables?...Or is it a problem that doesn't always make that block look bad or corroded?
Exactly.Electrical connections can "look" just fine, from the outside. But, it never hurts to take them apart and inspect the actual connection. Also, I've seen battery connections that also "look" just fine, but the cable underneath the pristine looking insulation was corroded and making a horrible connection with the clamp that attaches to the battery terminal.
Must've been a Cajun BeetleExactly.
Externally the connections all appeared fine, but once separated, you could see the green/white corrosion underneath.
Also the fuses were "blackened".
LMAO - Hmm... Blackened Bug... I bet Andrew Zimmern would love to taste that!Must've been a Cajun Beetle![]()
