The passenger seat rail is getting almost hot enough to burn. The plastic is not melting but you can smell it. Looked at it after dark and its not glowing. Don't have any power loss. What temp should it get? i have a IR heat gun to check it. Any suggestions?
Never threw any codes. Got it on the rack today. Had a small split in the resonator, throwing hot exhaust at the heat shield. Cut it out and replaced with pipe. No increased exhaust noise either.
