I bought my wife a 2003 GLX 1.8t convertible new. The 2003 was the first year for the convertible and we had a lot of issues with the windows, but this was resolved with updating the windows regulators and motors to 2005 and things have been fine since.
This has been a daily driver and has spend most of its life outside. It is now been handed off to my 16 year old daughter, but I have fun with it as I have to test drive and shake down the car for her.
Here is what I can tell you. No issue in the Winter time, the Beetle heater CRANKS, heated seats are great, would never own a car without them. In a vert heated seats are great for cooler top down days as well.
The tops typically hold up for 10+ years, BUT, there have been a lot of problems with the rear window coming unglued, took 10 years for mine to finally come unglued. You can fix them, its not easy or fun, but you can nurse the rear window for a few more years. No issues with snow, actually if you brush the snow off and there is any sun, the convertible will warm up and melt snow off faster than a metal top.
Door latches are problems in these cars, partially as they are fragile and complex, partially because with the convertible the window drops to clear the top when opened and the top does not hold back pressure when closing the door. You can close the door with your pinky, but most people SLAM them.
Automatic transmission have had valve body problems, not sure if and when they resolved the issue, I would try to get a 2008 or newer if I had to buy today.
I have yet to have problems with the top, but you are more likely to have problems, so just be prepared.
As for theft, yes you can cut a top easily, but on these cars you would have to pull the inside door handle to open the door, so likely a window will be broken before the top will be cut. Hope this is the case as door glass is cheaper and easier to repair than the top anyway. Just do not keep things in sight that would be interesting for thieves.
As they say, YOLO (You Only Live Once), so I would consider it and hope that you maintain the car well and you should have a fun and reliable car. My car has never left us stranded, but it has had its share of problems.
