Didnt want to use the vw clips. Searched for a z shaped spring barbed clip. Found some on ebay used for land rover front door window rubber trim . Bought couple packets. 44 in all for about 14 quid. Lots left over but sorted the detatching liner problem brilliantly. Clip the one side onto rear window trim. And liner into the protruding part of the z clip. Easy and invisible ....problem solved. Will print part number later so you can get the same or similar if you have the problem. And these dont break
