Help my top worked yesterday now top won't go down and driver window both have no power is this possibly a fuse?
I had the same issue and found out there is a sensor that detected the window was basically pinching causing a shut off. The fix for me was pull the door panel off and unplug the relay to the window motor then plug it back in and lower the window. The top would then function as normal. Good luck
