Ok, got his little Beetle bolted back up after the water pump timing belt job.
I had taken the reservoir off while doing the job, bolted it back in, connected the hoses and filled it up with coolant. I didn't drain the whole system before I did the job, so I only dumped coolant out of the reservoir and lost coolant from the water pump when I took it off.
When I bought the car at auction, the water pump was dripping and losing coolant slowly, I just kept toping it off when I needed to move it, but drove only when I needed to bring it home from the auction and from my home to my shop.
Driving it then, the heater worked and the car drove fine and didn't overheat, I just kept having to top off the coolant that was leaking from the pump.
Since the pump change, I fired up the car with the top off the overflow and attempted to burp the system. After about 15 mins of running, the water never really went down in the overflow like I thought it would when the thermostat opened, but instead started to bubble and boil. I put my finger down in the overflow and it was hot. I thought maybe it was just air bubbles but it was hot. Never had that happen before. I felt the hoses from each side of radiator and they both felt warm. I turned the heat on inside the car and I got nothing. It's like 7 degrees outside and the air coming out of the vent was like spitting ice cubes.
I decided to change the thermo stat and got the same result. When the thermo stat housing was off I had my cousin turn the car on and could see the new water pump pushing water. He turned it off and I checked inside with my fingers and everything was nice and clean.
The fins on the radiator are cold to the touch. It doesn't feel warm at all, but both hoses coming out of it feel warm to hot although I don't know if I feel much coolant in the top hose, doesn't feel right.
The driver side fan kicks on, but the smaller pass side fan feels like the bearing is locked up, I have to really push on the blades to get it to move and it won't kick on, and I think I could smell burnt electrical smell coming from it on one of the start ups. I will need to replace it, but I can't believe that would be causing this.
I can't tell if the engine is actually overheating or if the little red light coming on is just the low coolant signal. I only lose coolant if I put the cap back on, seems to boil over and run out the overflow. Otherwise it just seems to boil. When the light goes off I shut it down, but I can put my hand on the top of the engine and it is warm to hot, but I can hold my hand there and it's not hot enough to burn me.
I really don't think its a head gasket issue. I don't think I have enough pressure for it to be the head gasket. The oil is nice and clear of any air bubbles or coolant. The car ran fine before the water pump job and the heater worked fine.
I feel like I have some type of blockage or air pocket.
Should I just drain everything and start over? I'd really like to flush the heater core with a garden hose to be sure but it's 7 degrees here and I can't really work with running water outside.
Any other ideas? Anything I could be missing? Any tricks or tips to burping this system?
Thanks again
Thanks again
