Hey guys I just got done replacing the vacuum pump gasket yesterday and i noticed that I am leaking coolant from these hoses.
Do you guys know what these hoses are called?
Also when I replace these hoses do I have to drain all of the coolant out?
Thanks
[/QUOTE]
Thanks
[/QUOTE]
Do you have an auto trans? If so how were you able to make the repair without unbolting the tranny? I was told by a local mechanic that you needed to loosen the tranny and push it back some in order to get the vacuum pump out. Is that the case? Looking for options as I have a leak and need to get it fixed. Thanks for any info.
I have an 06 beetle w/ auto trans btw.
I have an 06 beetle w/ auto trans btw.[/QUOTE]
Yes the beetle does have an automatic transmission. I followed this how-to to get it done.
VWVortex.com - DIY: The first ever guide to replacing the 2.5L vacuum pump WITHOUT special tools or dropping the trans
