1 - 20 of 22 Posts
· Registered
2003 NBC 2.0l has been running hot and causes high temp CEL. Suspected water pump since return flow to reservoir was non existent and would produce bubbles in reservoir if blown into. Pulled water pump, it looked ok. Also Pulled and tested the thermostat and it was ok.
Is there any other blockages that I should check for?
Heater core gas been bypassed before I bought this.
· Registered
What temps are you seeing, are you seeing any specific light modes in the speedo cluster come on and/or monitoring the temps using a scan tool; then used a infrared temp gun to confirm this or see, any visual aspects of overheating like boiling coolant in the coolant tank or overflowing coolant, cooling fans on constant max high speed, etc?
Here are the coolant light modes:
On the trouble code side of things; please post any codes, you are getting.
Here some videos; going over overheating issues and things to check, by exovcds on youtube:
More videos of his to review; from more checks to refilling the coolant.
· Registered
· Registered
Check engine light with P0116 code. No temperature warnings after warmup. Seeing a blue temp indicator for the first few minutes as expected. Haven't replaced the temp sensor yet. Cleaned out passage on right side of head. It initially had a restriction.
I was seeing 210°+ before cleaning out passage and blowing out the reservoir return line going through the throttle body. Last test was showing 195° after about 20 minutes of idle time. It was normally triggering the fans on and off.
All readings were done using Obdeleven.
Sent from my SM-N975U1 using Tapatalk
· Registered
Based, upon the temp monitoring results; technically, those are in the normal range. The code, seems to point to; a possible defective coolant temp sensor?
Review the videos; return coolant, into the tank, would be normal cooling system operation. We have seen cooling systems; that were contaminated, with incorrect mixed green, vw pink g12/13 coolant, which developed into a nasty, thick coagulated mess, that plugged up various hoses and passages.
You might pull the cooling tank return hose; try to blow through it. I had one that was clogged; many have a plastic flow restricter with a tiny coolant passage. In that case, i took a small stiff wire; pushed though the blocked passage, cleared the obstruction, flushed out the hose, blew out with compressed air and confirmed free flow with water. I reinstalled and the coolant flow was restored.
In the case of the contaminated vw Jetta withba 2.0L i worked on; the coagulated junk tended to rise to the higher hoses, passages and coolant tank. I had to remove, a bunch of hoses and use wires, to push out blockages and pipe cleaners to scrub everything out with dawn dishwashing soap and finish off by flushing the whole cooling system, until the water was clear, gunk was mostly gone.
Normally the hoses should have been replaced but the customer was tight on cash and we did the best we could by cleaning and flushing the whole system and it ended up working fine, cooled in normal ranges, didn’t over heat.
However, not being the ideal repair; some residual tiny bits of junk remained floating around, even after 3 flush cycles but didn’t seem to affect cooling system operation.
You may need to remove a bunch of hoses and confirm; free flow from the many areas of the cooling system, clean them out, blow out with compressed air and flush the system throughly, until water runs clearly.
Then, refill the system with coolant and ideally; use a vacuum fill tool and see if things flow, as they should and review the exocvds videos to follow overheating checks, to confirm flow and operation is normal.
· Registered
Discussion Starter · #8 ·
Thanks Billy. As I stated in my first post I did have a restriction in the return line that I think I cleared. Actually I haven't had anything but water in the system since I replaced the head last year. Going to do a good flush and replace all the coolant and see how things are now.
· Registered
So, has the water pump, coolant temp sensor and/or the thermostat been replaced? Ok, report back your results and we can go from there.
· Registered
Discussion Starter · #10 ·
Water pump replaced, thermostat replaced. They both are so difficult to get to, you would be crazy not to replace them.
I've been a little sidetracked with some other issues that came back. Mainly #4 fuel injector.
· Registered
So, did you get the overheating issue and/or the coolant temp sensor, replaced?
As to the injector and previously mentioned cooling related problem; are there any trouble codes or have you cleared them, see what comes back?
· Registered
Discussion Starter · #12 ·
So far I think the over heating issue is ok.
In regards to the fuel injector issue, this really is pissinf me off. Until I changed the water pump and timing belt the engine was running perfectly. No misfires
Last scan:
· Registered
Ok, I think we discussed this before; what troubleshooting, testing or repairs have you performed, on this issue? Any parts replaced?
Also, as always, post the trouble codes and not just the descriptions. Thanks.
· Registered
Since, you are using OBDEleven; you might review this video and use it, to read live data, the misfire counter as the engine is running.
· Registered
Discussion Starter · #15 ·
Yes, it was resolved a few weeks ago. Except I was getting misfire codes with no misfires actually occurring. Now I'm seeing consistent misfires on #4 cylinder.
· Registered
So, i guess you need to revisit the misfiring issue; what testing, troubleshooting, repairs have been done and/or new parts, have been installed?
· Registered
Discussion Starter · #17 · (Edited)
Right now I'll caulk it up to dirty injectors. Ran a bottle of fuel injector cleaner with 1/4 tank and ran it a few miles of running hard and fast. So far it's not acting up. Keeping fingers crossed. Cooling system seems to doing good. Still going to do a good flush though.
Thanks Billy
· Registered
Discussion Starter · #20 ·
I'm still curious about something though. I realize you can jumper the Fan connector on the wiring harness, if both speeds turn on does that only point to the fan switch or could the fan control module still be bad?
Sent from my SM-G998U1 using Tapatalk
1 - 20 of 22 Posts
