My '04 was diagnosed by AutoZone as having a "Cooling System Performance Problem" after the "check engine" light came on.
FYI the water pump was replaced 10 months ago along with the timing belt and tensioner. Also the car is exhibiting no other problems e.g. no idiot lights are coming on indicating overheating; engine temp seems normal; no visible leaking; hoses seem fine; coolant level in expansion tank high.
This is the 2nd time this happened. The first was about 10 days ago. I had the code cleared, drove it about 2000 miles on a trip, then it happened again today.
Any suggestions or things to check would be appreciated.
You all have a great day.
trshman
trshman
