1 - 9 of 9 Posts
Vapor Transmission
VAG-COM Version: Release 311.2-N
Control Module Part Number: 06A 906 032 C
Component and/or Version: 1.8l 5VT NB HS G 3077
Software Coding: 00001
Work Shop Code: WSC 00066
4 Faults Found:
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 35-00 - -
17526 - Oxygen (Lambda) Sensor Heating: B1 S2: Open Circuit
P1118 - 35-10 - - - Intermittent
17606 - Oxygen (Lambda) Sensor Heater Circuit: B1 S2: Electrical Malfunction
P1198 - 35-10 - - - Intermittent
16523 - Oxygen (Lambda) Sensor B1 S2: Response too Slow
P0139 - 35-10 - - - Intermittent
Now i know the First code is for my 3" Exhaust system, i have had it since i put thee 3" DP in. But the Folowing 3, i have been geting Recently, can anyone tell me what they mean?:confused:
Save a horse, ride a....
You need a new o2 sensor...Bank 1 Sensor 2...not sure but I 'think' this is the rear o2 sensor
a.k.a. porkchopzz4
While these codes are most likely the O2 sensor, I was getting some of the same codes and it was MAF - apparently the MAF wasn't far enough out of spec to throw a MAF code, but was screwing up the A/F ratio enough to throw a code downstream at the O2 sensor. So... if you've got new O2 sensors, I'd look at the MAF.
Vapor Transmission
I replaced my MAF about a Year ago lol :mad:
According to Bentley on CD its the O2 sensor behind the catalytic converter. The new Bentley CD won't allow cut and paste, what a bummer.
a.k.a. porkchopzz4
That doesn't mean it isn't bad again... :)
1 - 9 of 9 Posts
