I can not find the crank sensor/ impulse sensor on my "new" bug. It is a 98 and a fix me upper. It does not start often sounds like its flooded when I first try. I can often put it in gear for 3 minutes and then put it back in park then it will start. It is driving me crazy.
Here is to hoping it starts today.
Jitterbug
Scan it for codes first, the symptoms such as they are might point to the start-in-neutral/park switch...
i agree.....except for the car will not crank if the nuetral safety switch is bad....i'm not sure if it will crank if the CPS is bad.but yeah, scanning the code will tell you alot more about what is up.
