Hey All!
I am new to the group but own a 03 2.0L beetle.
I replaced the CV axles and suspension about a month ago. Once I replaced them, I noticed my beetle had a vibration accompanied by a loud "hole in the muffler" type sound whenever I hit 3800-3900 RPM in any gear. I re-checked the work and everything is installed correctly. The CV axle is after market and I am wondering if the axle could cause this type of issue. I ended up taking the beetle to the VW dealership to see if they could figure out what was causing the noise and they thought it was due to the engine mounts needing replacement. I ended up replacing the engine mounts and it did not solve the problem. Now, while I am happy with the performance with the new engine mounts, it did not solve the noise and vibration issue. Has anyone had this issue with their beetle after replacing CV Axles? I am thinking it has to be the axles but don't want to spend another grand replacing them since they are brand new unless I have more info to go off of. This happens only at that RPM range and is not altered or changed by varying speeds.
Thanks for your input!
