Hope somebody can help me.
I damaged my thread on my CV shaft where the 30mm nut goes on when removing it.
I'm thinking about using a tap and die set to fix the thread.
Does anyone know what size I would need?
for example 3/4 coarse thread or M22 x 1.50
Unsure if those are the right size just ideas.
I really dont want to have to replace the part :S
Thanks,
Kate
The thread may not be a standard one. The nut is self-locking. I've noticed that the shape of the threads on bolts that use self-locking nuts do not look like standard threads. I'm talking about the cross-sectional shape of the thread, not the diameter and pitch.
Hmm, idk. All I know is that my nut wont get tight and when I purchased a new nut from the stealership I couldnt start it :(
You can repair the threads; using a special die or trying a thread file, to restore the threads.
There are specialty tools; to do this correctly, I don't know the specific thread/size of the die you would need. They are sold; many times, under the Kastar brand of tools.
They call them a: "Axle End Thread Restorer Kit"
Rethreader Tools - Hand Tools
You could also; try using a thread restore file, for a less expensive solution:
SKU : 2573 - 3-PC. Thread Restorer File Set - Rethreader Tools - Hand Tools
From what I can tell; the axle/nut is: 20MM by 1.5mm thread pitch.
Example:
NEW Rein Automotive Axle Nut Volkswagen OE N90587602
Front axle nut. 2 per car. 20x1.5mm. Part Fits: Volkswagen: Beetle 1998-07 | Corrado 1992-94 | Golf 1995-06 | Jetta 1994-05 | Passat 1993-97
In that case; this kit seems to have the one you need:
SKU : 2579 - 8-Piece Fractional and Metric Spindle Rethreader Set - Rethreader Tools - Hand Tools
You might give them a call and see if you could purchase the 20MM by 1.5mm die by itself:
A&E Incorporated
Customer Service - 1-800-645-1142
You might be able to order it at your local industrial supply shop or online:
20mm x 1.5 Carbon Steel Hex Rethreading Die - Amazon.com
https://www.google.com/search?q=20m...+X+1.5mm+Pitch&rls=org.mozilla:en-US:official
Thanks so much!!! Thats exactly what I needed to know.
I will seek a 20mm x 1.5 die.
So glad Im part of this forum. :)
