I have a 2000 beetle tdi it has good heat but the window won't defrost, it's like it has a film on it. I can clean it with windex and it will be clear as a bell for about 5 to 10 minutes then it starts to fog back up. can anyone tell be what is causing this problem. I'm tired of having to squeegee the window as I drive.
Do you have a sweet smell in the car? If so it is most likely the heater core leaking. Antifreeze can leave a film on the windshield.
Also are you getting heat to the defroster? The blend and selector door foam can fail and then don't direct heat very well.
