Okay I got this done!
I originally meant to do this with the compressor mounted, but I ended up unbolting it (but left the hoses connected). Its near impossible to do it mounted to the bracket.
For anyone who plans to do this in the future, here's my tips:
- REMOVE the passenger side headlight, the headlight bracket, throttle body, serpentine belt tensioner, and alternator to gain easier access to the A/C clutch
- DISCONNECT upper radiator hose (connected to thermostat) so you can lift A/C compressor for easier access
ALTERNATOR/COMPRESSOR REMOVAL AND INSTALL TIPS
You need to pry out the alternator and A/C compressor from their mounts, this is why you should remove the throttle body so you can use a prybar on them. Once they are removed, you should use a socket and the mounting bolt on the reverse side of each bushing to make it easier to re-install them once you are done (they are almost impossible to reinstall without doing this)
A/C CLUTCH REMOVE AND REPLACE TIPS
Very carefully lift the A/C compressor up as high as the hoses will allow. This should give you very good access to the A/C compressor clutch. I then used a wire to hold the compressor at this location while I worked on the clutch.
1) I used an A/C clutch removal tool to hold the clutch plate while I removed the 13mm nut.
2) Below the upper plate is a shim which maintains a minimum distance between the clutch plate and the clutch pulley. SEE BELOW.
3) The clutch pulley is held on by a internal retaining clip that can be removed with flat head screwdrivers, but I recommend getting internal circlip pliers. Once you remove the retaining clip, the clutch pulley can be removed by pulling with your hand or gently prying with screwdrivers (BE CAREFUL, beneath the clutch pulley is the electromagnet which is a separate piece, do not pry on the electromagnet)
4) The clutch electromagnet is held on by another internal retaining clip. Its wire is held in 2 locations, the closest location has a tab that can be bent back with a flat head screwdriver. The second one needs to be removed with a Phillip head, but mine was corroded and so tight I had to drill it out, and zip tie the wire to the compressor body.
NOTE ABOUT SHIMS: Between the clutch plate and the clutch pulley, you need to install shims which maintains a distance between the clutch plate and the clutch pulley. If you do not use enough shims, the compressor will be engaged all the time, and you will burn something out. Once you install the clutch plate, try spinning the pulley, if you hear/feel any resistance, you need more shims. The flipside is that if you use too many shims, you reduce the life of the clutch material.
